3D subfields issue
Paul.Rodden
I have version 6.07
In the Module Layout page. I am getting issues with the 3D sub fields . In my 3D construction I have 18 seperate rectangular array fields set up. When I go the Module Layout page it does not have all the 3D subfields. It has 18 fields but three are repeats of existing fields and three are missing. I have tried renaming, reloading , deleting and reentering...nothing works...I just get variations on the same problem
PVsyst seems very buggy....or is it just me?
array fields
  • 3 weeks later...
I am getting the same issue, I have created a shading scene and when I go to module layout I am getting a completely different set of subfields.
When I click 'erase def' (which has worked for me in the past with this situation) the dialog simply closes and when I open it up again, I am getting the same set of incorrect subfields.
Has a solution been found to this problem?
  • 1 month later...
The "Module Layout" list of subfield did not renew when you are asking an update from the 3D scene.
A solution was to restart the Module definition from scratch (i.e. button "Erase Def.")
This problem has been solved in the version 6.12. The program now updates from a modified 3D scene, and keeps what it can from previous definitions.
