st14m21 Posted May 16, 2021 Posted May 16, 2021 I want to change from shading to sheds to use Bifacial.The panels are imported from PVC files.In the Orient section, I set Unlimited sheds, but it doesn't change!Can someone please help me!Thank you!
Michele Oliosi Posted February 8, 2022 Posted February 8, 2022 If your shading scene is regular enough you can still use it alongside the "Fixed plane" orientation and use the bifacial model as well.In the current version (7.2.11) I haven't been able to reproduce the issue you describe. If you keep experiencing this bug please send us an email with your project or more information.
