Cloud 9 Posted July 1, 2013 Posted July 1, 2013 I am looking at buying PVsystBut need to know if it deals with the following (otherwise its no good for me)1. Micro Inverters (Like EnPhase) with different sading factrs on multiples of panels2. More than 2 orientations and angles of roofs Currently have a project with 6 roofs, of which i have lots of shade depending on the time of day due to the roofs and 4 different angles with 4 different orientations.....Thanks
André Mermoud Posted July 2, 2013 Posted July 2, 2013 Yes PVsyst allows working with Micro inverters, and Enphase inverters are in the database. You can define at most 2 different orientations in a same simulation. However you can do a simulation for each subsystem, i.e. each orientation independently, including a shading analysis. And then simply add the results for your complete system.
Cloud 9 Posted July 2, 2013 Author Posted July 2, 2013 HmmNot sure i understandif i sent you the property details and the roofs and and orientations would you run it through and send me a pdf so i can take a look at the output ?
Cloud 9 Posted July 2, 2013 Author Posted July 2, 2013 ThanksA bit convoluted for something thats not a cheap software package :-(
