tpant Posted February 10, 2021 Share Posted February 10, 2021 Hi,I am trying to model a tracker array with bifacial modules on a terrain that is 2.6° tilted to the north.We modelled the project at 0° axis tilt earlier as the trackers would be made horizontal by having different height posts. However, also wanted to model it with the axis tilt of the terrain just to see what the yield difference would be.The issue is as soon as I adjust the tracker axis tilt(-2.6°) in the shade scene and update the orientation, I get the following error:Your PV System is for the bifacial 2d model comparison. You should choose "Unlimited trackers" in the "Orientation" part, or define regular tracker array(s) with N/S horizontal axis in the 3d.This work fine if I change the axis tilt back to 0, but throws this error as soon as I change the tilt. Also, if I choose the unlimited tracker option, there is still no option to define an axis tilt.Is there a workaround for this issue? Link to comment Share on other sites More sharing options...
Bruno Wittmer Posted February 11, 2021 Share Posted February 11, 2021 Currently the bifacial model in PVsyst that is used for trackers, allows only a horizontal axis and a flat terrain.The error message is not very clear on that, it should be improved.Allowing an axis tilt for bifacial trackers would only be useful in combination with a possible terrain slope, and both should be able to vary independently of each other. This will need considerable reworking of the bifacial model. Link to comment Share on other sites More sharing options...
Ray_T Posted February 13, 2021 Share Posted February 13, 2021 Hello. I have the same issue. I am also trying to model bifacial with SAT with a slight tilt. I get the same error message.If I turn off near shading it seems to accept the model but of course I would like to run the model with near shading on.Is there anyway to approximate the tilt in the model, keep the shading analysis and generate the report?Thanks.Ray Link to comment Share on other sites More sharing options...
GMO Posted February 19 Share Posted February 19 Hi! Is this problem already solved? Or is there a way to avoid it? Thank you Link to comment Share on other sites More sharing options...
