MichalStepniak Posted January 21, 2021 Share Posted January 21, 2021 Hi :)I'm preparing a simulation for solar farm and my arrays look like this:(inverter x strings / modules in the single string)4 x 48/332 x 24/321 x 10/32 and 2/33My issue is the last inverter. How to config PVsyst so it can show two different configurations in one inverter?There is single inverter that has 12 strings. 10 strings of 12 overall have 32 modules, 2 strings of 12 overall have 33 modules.It's easy for first two configurations as I just make 2 sub-arrays, but I'm lost at 3rd sub-array for the last inverter.I was trying to use multi-MPPT feature but I havent found any step by step explenation how to use it. Link to comment Share on other sites More sharing options...
dtarin Posted January 29, 2021 Share Posted January 29, 2021 Search the forums, there are some existing posts. https://forum.pvsyst.com/viewtopic.php?f=25&t=5073&hilit=mpptArrays 1 and 2 are straight forward. Arrays 3 and 4 in PVsyst are the two configurations for the last array. In these two arrays, you will check the mppt share box, and balance power Subarray 1: 48 strings, 33 modules in series, 4 inverters totalSubarray 2: 24 strings, 32 modules in series, 2 inverters totalSubarray 3: 10 strings, 32 modules in series, 5 mppt inputs (check "use mppt sharing")Subarray 4: 2 strings, 33 modules in series, 1 mppt input (check "use mppt sharing")I dont know what inverter you are using, but you can modify it to have 6 mppt inputs. Allocate 5 to subarray 3, and 1 to subarray 4. The link above should help. This will be equal to 1 inverter. Link to comment Share on other sites More sharing options...
