sachidanandam Posted June 8, 2013 Share Posted June 8, 2013 The product (GlobInc * Pnom) is numerically equivalent to the Energy which would be produced if the system was always running with its nominal efficiency as defined by the nameplate nominal power [kWh].HOW DIMENSIONALLY EQUAL Link to comment Share on other sites More sharing options...
André Mermoud Posted June 11, 2013 Share Posted June 11, 2013 There is often a unit's confusion with the quantity Yr, which may be understood : - either as the incident energy (with units [kWh/m² / day]) - or as the ideal array Yield according to Pnom (expressed as [kWh / kWp / day]). This numerical identity results of the STC definition: one kWh/m² of irradiance should produce one kWh/kWp of electricity. The confusion comes from the fact that the kWh are not the same:- in the former case [kWh/m² / day], the kWh represent incident irradiance energy (light flux) - in the latter case [kWh / kWp / day], the kWh mean produced electrical energy !!! Link to comment Share on other sites More sharing options...
