Several orientation in a same inverter
shahaf
Hello ,
If i have several orientation with different size of strings length - Could I make the inverter as multimppt and power each orientation to a specific mppt???
In this case if i would put the same type of inverter to each sub array that combine on this multimppt inverter??
THX ALOT!!!
  • 1 year later...
Hi,
When you have a different number of strings on the MPPT inputs, you should create one sub-array for each configuration (for example one sub-array for the MPPTs with a single string, and another one for the MPPTs with two strings).
Then, in ‘power sharing’, you tell PVsyst which sub-arrays belong to the same inverter and how the power of the inputs is balanced.
