kjs55 Posted September 25, 2020 Posted September 25, 2020 PVsyst v6.8.0. The date column of the output CSV file varies back and forth several times from this format:12/11/2018 11:00:00 PMTo this format:13/11/18 00:00Steps to see this: 1.) Run simulation, 2.) Save hourly output CSV file, 3.) Open in Excel, 4.) Convert text to columns via semicolon delimiter, 5.) Look at date columnIs this bug fixed in PVsyst v7?
jtp4652 Posted April 1, 2022 Posted April 1, 2022 On 9/25/2020 at 2:57 PM, kjs55 said: PVsyst v6.8.0. The date column of the output CSV file varies back and forth several times from this format: 12/11/2018 11:00:00 PM To this format: 13/11/18 00:00 Steps to see this: 1.) Run simulation, 2.) Save hourly output CSV file, 3.) Open in Excel, 4.) Convert text to columns via semicolon delimiter, 5.) Look at date column Is this bug fixed in PVsyst v7? Have you found a fix to this issue?
aspf Posted March 17 Posted March 17 Hi, I am running on ver 7.4.8 and i also faced the same issue. I have problems extracting respective day, month, hour and minute values from the raw data (1st column) despite trying "text to columns". Is it a bug from PVsyst and is there a way to fix this? The additional steps to reformat the date are taking up more time than expected.
Michele Oliosi Posted March 17 Posted March 17 Hi, It's more likely a problem of compatibility of the PVsyst output with the regional format on your Excel/Windows installation. In PVsyst you can try changing the format and see if anything helps There are also more options on Excel, but I'm no expert there:
Michele Oliosi Posted March 17 Posted March 17 If you can, let us know what you find that would be great.
kjs55 Posted December 6 Author Posted December 6 None of the methods proposed thus far in this thread work for me over the entire PVsyst date column. You can see the problem if you open the PVsyst output CSV file in Excel and add a new column with the formula =DAY(PVsyst_date) and drag it down. The root problem is that the PVsyst output date column contains mixed data types/formats (both serial numbers and text strings). Here is what I finally found to work for the default PVsyst output date format "DD/MM/YY; Hour; (Excel)": year =IF(ISNUMBER(PVsyst_date+0),YEAR(INT(PVsyst_date+0)),1900+VALUE(MID(TRIM(PVsyst_date),7,2))) month =IF(ISNUMBER(PVsyst_date+0),DAY(INT(PVsyst_date+0)),VALUE(MID(TRIM(PVsyst_date),4,2))) day =IF(ISNUMBER(PVsyst_date+0),MONTH(INT(PVsyst_date+0)),VALUE(LEFT(TRIM(PVsyst_date),2))) hour =IF(ISNUMBER(PVsyst_date+0),QUOTIENT(ROUND(MOD(PVsyst_date+0,1)*1440,0),60),VALUE(MID(TRIM(PVsyst_date),10,2))) minute =IF(ISNUMBER(PVsyst_date+0),MOD(ROUND(MOD(PVsyst_date+0,1)*1440,0),60),VALUE(RIGHT(TRIM(PVsyst_date),2))) second =IF(ISNUMBER(PVsyst_date+0),MOD(ROUND(MOD(PVsyst_date+0,1)*86400,0),60),0) xlsdatenum =DATE(year,month,day) + TIME(hour,minute,second)
