Bifacial Performance Ratio
mmsyther
How does PVsyst calculate its performance ratio with Bifacial modules?
Is the Irradiance just the front side that it uses for its performance ratio calculation?
Or does it take into account the rear side Irradiance?
I can't seem to find anything useful on this.
  • 1 month later...
As I understand, PVsyst 6.86 uses only front side irradiation for calculating PR.
This is evident when rear side irradiation is significant which results in >100% PR.
Try running bifacial simulation with E-W configuration.
Hope it helps.
  • 3 weeks later...
Hello
No, it doesn't take the rear side irradiance into accounu, until know the biracial performance ratio is calculated as the mono-facial.
"PR for bifacial systems
The definition of the performance ratio should be something like a standard, defined by an official instance, and accepted by everybody.
Now I have not yet seen any reference which would define a performance ratio for bi-facial systems. Therefore PVsyst cannot propose any specific value in the present time.
The value provided presently with the PVsyst results uses the definition of the Monofacial systems, so that the bi-facial gain comes as an increase of this ratio.
NB: The main objective of the PR is to find an indicator for comparing real and simulated data, therefore which may easily be evaluated using simple (and "primary") measured data.
However neither the rear side irradiance, nor the part of the bifacial gain is available in usual measurements."
Source: https://forum.pvsyst.com/viewtopic.php?t=31
Best Regards,
Nedal Nassar
  • 1 year later...
Hello
Best Regards,
Nedal Nassar
And what about now... IEC 61724-1:2021 is available!
  • 6 months later...
Since version 7.2.13 you will find a bifacial performance ratio in the results summary window.
This bifacial performance ratio is computed as:
PRbifi = PR / (1 + (GlobBak + BackShd)/(GlobInc))
(see https://www.pvsyst.com/help/performance_ratio.htm)
Note that this may not correspond to notes 1 and 2 of §3.20 in the norm IEC 61724-1:2021, since it does not include the bifaciality factor. It is instead based on a literal interpretation of the IEC 61724-1:2021 §3.20 main paragraph.
At the moment IAM losses are automatically included in the irradiance contributions. Therefore measurements (e.g. with a pyranometer) may differ from (GlobBak - BackShd). As you mentioned in another topic, we will think about adding an IAM loss estimate so that we can remove it from the PR normalization.
