mmsyther Posted February 21, 2020 Posted February 21, 2020 How does PVsyst calculate its performance ratio with Bifacial modules?Is the Irradiance just the front side that it uses for its performance ratio calculation?Or does it take into account the rear side Irradiance?I can't seem to find anything useful on this.
Muthuraj Posted March 22, 2020 Posted March 22, 2020 As I understand, PVsyst 6.86 uses only front side irradiation for calculating PR.This is evident when rear side irradiation is significant which results in >100% PR. Try running bifacial simulation with E-W configuration.Hope it helps.
nassar Posted April 8, 2020 Posted April 8, 2020 How does PVsyst calculate its performance ratio with Bifacial modules?Is the Irradiance just the front side that it uses for its performance ratio calculation?Or does it take into account the rear side Irradiance?I can't seem to find anything useful on this. Hello No, it doesn't take the rear side irradiance into accounu, until know the biracial performance ratio is calculated as the mono-facial. "PR for bifacial systemsThe definition of the performance ratio should be something like a standard, defined by an official instance, and accepted by everybody.Now I have not yet seen any reference which would define a performance ratio for bi-facial systems. Therefore PVsyst cannot propose any specific value in the present time.The value provided presently with the PVsyst results uses the definition of the Monofacial systems, so that the bi-facial gain comes as an increase of this ratio.NB: The main objective of the PR is to find an indicator for comparing real and simulated data, therefore which may easily be evaluated using simple (and "primary") measured data.However neither the rear side irradiance, nor the part of the bifacial gain is available in usual measurements."Source: https://forum.pvsyst.com/viewtopic.php?t=31Best Regards,Nedal Nassar
bapossatto Posted October 15, 2021 Posted October 15, 2021 How does PVsyst calculate its performance ratio with Bifacial modules?Is the Irradiance just the front side that it uses for its performance ratio calculation?Or does it take into account the rear side Irradiance?I can't seem to find anything useful on this. Hello No, it doesn't take the rear side irradiance into accounu, until know the biracial performance ratio is calculated as the mono-facial. "PR for bifacial systemsThe definition of the performance ratio should be something like a standard, defined by an official instance, and accepted by everybody.Now I have not yet seen any reference which would define a performance ratio for bi-facial systems. Therefore PVsyst cannot propose any specific value in the present time.The value provided presently with the PVsyst results uses the definition of the Monofacial systems, so that the bi-facial gain comes as an increase of this ratio.NB: The main objective of the PR is to find an indicator for comparing real and simulated data, therefore which may easily be evaluated using simple (and "primary") measured data.However neither the rear side irradiance, nor the part of the bifacial gain is available in usual measurements."Source: https://forum.pvsyst.com/viewtopic.php?t=31Best Regards,Nedal Nassar And what about now... IEC 61724-1:2021 is available!
dtarin Posted October 18, 2021 Posted October 18, 2021 Manually calculate PR and include the rear-side irradiance with the front-side irradiance.
Michele Oliosi Posted April 28, 2022 Posted April 28, 2022 Since version 7.2.13 you will find a bifacial performance ratio in the results summary window. This bifacial performance ratio is computed as: PRbifi = PR / (1 + (GlobBak + BackShd)/(GlobInc)) (see https://www.pvsyst.com/help/performance_ratio.htm) Note that this may not correspond to notes 1 and 2 of §3.20 in the norm IEC 61724-1:2021, since it does not include the bifaciality factor. It is instead based on a literal interpretation of the IEC 61724-1:2021 §3.20 main paragraph.
dtarin Posted April 30, 2022 Posted April 30, 2022 Are rear IAM losses included when computing the bifacial PR?
Michele Oliosi Posted May 2, 2022 Posted May 2, 2022 At the moment IAM losses are automatically included in the irradiance contributions. Therefore, measurements (e.g. with a pyranometer) may differ from (GlobBak + BackShd). As you mentioned in another topic, we will think about adding an IAM loss estimate so that we can remove it from the PR normalization.
SPdesai Posted April 5, 2025 Posted April 5, 2025 What is the signage of the BackShd term. Is the loss being subtracted from rear irradiance or added to it? If the signage is negative- why is it being subtracted? Isn't GloBak (global irradiance on the rear side) achieved by already accounting for the shading losses? The flow diagram in the PVsyst report indicates it and the calculation checks out as well. Aren't we double counting? If the signage is positive, why are we adding it back? Is it to match the PR measured on site where the rear irradiance may be measured by rear POA sensors that are mounted on the torque tube and hence not accounting sufficiently for the rear shading factor?
Michele Oliosi Posted April 7, 2025 Posted April 7, 2025 @SPdesai Sorry it seems there was a wrong sign in my answer above. I have corrected it. The sign is positive. We are adding it back, indeed. Indeed, we expect that the rear POA sensor will not be shaded (mostly) by mounting structures or cables.
