Jahan Prova Posted February 12, 2020 Share Posted February 12, 2020 My assignment is to design a solar farm in Melbourne. My professor asked for the system design along with annual solar panel performance with hourly internal data.Only info given are-Location- Melbourne, AUSSystem Capacity: 4.95MWPanel Type - Trina 450W DE17M(II)Inverter Type - ABB PVS980-58-5000kVA-LNumber of Panels: 11,000Number of Inverters: 1Mounting Type: Single Axes TrackerMounting Model: Nextracker NX Horizon Link to comment Share on other sites More sharing options...
André Mermoud Posted March 4, 2020 Share Posted March 4, 2020 Such a system may easily be defined in PVsyst. You have all the required elements for that.You can get hourly data by defining a CSV output file (for EXCEL) using "Advanced simul > Output file". Here you can define the simulation variables you want to export. Link to comment Share on other sites More sharing options...
Patricia Posted March 18, 2020 Share Posted March 18, 2020 Such a system may easily be defined in PVsyst. You have all the required elements for that.You can get hourly data by defining a CSV output file (for EXCEL) using "Advanced simul > Output file". Here you can define the simulation variables you want to export. Hi, I do that but when I chose E_Grid ( in my case) and I push 'OK'. Later I dont know where I can look for the CVS file o how to export it. Link to comment Share on other sites More sharing options...
André Mermoud Posted May 24, 2020 Share Posted May 24, 2020 After defining the data you want to get in the CSV file, please don't forget to check "Datafile output / Output on filename" top left. The file will be available at the end of the next simulation. The simulation will notify you where it is located (i.e. in your workspace \Userdata\). NB: You have to re-check the option "Output on filename" at each executions when you want an output file. NB2: This is fully explained in the help "Project design > Simulation > Simulation: export ASCII file", available by F1 in the importing tool. You have access to the Help by F1 (or little questionmark buttons for mor specific information) from everywhere in the software. Please use it. Link to comment Share on other sites More sharing options...
