Importing SolarAnywhere data - "Years considered..." issue.
I am having trouble importing a Solar Anywhere TMY hourly file into PVsyst 6.7.3. After selecting
"This file seems to be a TMY file, but the sequence “Years considered: XXXX thru XXXX” was not detected in the first line’
I tried adding this text to the first line with no success. I have read all the directions I can find but to no avail. I've also seen some other posts on this same issue but no solution.
Andre or others, can anyone offer a suggestion?
Brenden
If you imported the SolarAnywhere file as a .csv, you will use the NREL TMY3 format for import, no modifications needed.
Edit: I just tried importing a .csv solaranywhere file using the solaranywhere format and I also received that error, so I would suspect that is also what you are doing.
Yes, that works and is also what Clean Power Research (Solar Anywhere) recommends. I wonder what the SolarAnywhere menu selection is for then?
Thanks Solarguru!
Brenden
It is possible to download SolarAnywhere data as a .csv file or as a 'SolarAnywhere' file format, in which the latter would use the SolarAnywhere menu selection in PVsyst.
