Chewka Posted January 9, 2019 Share Posted January 9, 2019 Hello,I am having trouble importing a Solar Anywhere TMY hourly file into PVsyst 6.7.3. After selecting "This file seems to be a TMY file, but the sequence “Years considered: XXXX thru XXXX” was not detected in the first line’I tried adding this text to the first line with no success. I have read all the directions I can find but to no avail. I've also seen some other posts on this same issue but no solution.Andre or others, can anyone offer a suggestion?Brenden Link to comment Share on other sites More sharing options...
dtarin Posted January 15, 2019 Share Posted January 15, 2019 Have you figured this out? Link to comment Share on other sites More sharing options...
Chewka Posted January 15, 2019 Author Share Posted January 15, 2019 Not yet. Link to comment Share on other sites More sharing options...
dtarin Posted January 15, 2019 Share Posted January 15, 2019 If you imported the SolarAnywhere file as a .csv, you will use the NREL TMY3 format for import, no modifications needed. Edit: I just tried importing a .csv solaranywhere file using the solaranywhere format and I also received that error, so I would suspect that is also what you are doing. Link to comment Share on other sites More sharing options...
Chewka Posted January 21, 2019 Author Share Posted January 21, 2019 Yes, that works and is also what Clean Power Research (Solar Anywhere) recommends. I wonder what the SolarAnywhere menu selection is for then?Thanks Solarguru!Brenden Link to comment Share on other sites More sharing options...
dtarin Posted January 22, 2019 Share Posted January 22, 2019 It is possible to download SolarAnywhere data as a .csv file or as a 'SolarAnywhere' file format, in which the latter would use the SolarAnywhere menu selection in PVsyst. Link to comment Share on other sites More sharing options...
