1Plasmon Posted January 19, 2013 Posted January 19, 2013 Hello, How can I create an OND file for an inverter that is not listed on Photon D/B or in PVsyst library nor the supplier has it either? ThanksA.
cnrikio Posted January 21, 2013 Posted January 21, 2013 Have you tried to create a new OND file by filling the parameters in "Grid Inverter Definition" dialog? If no, you can access it from Tools/Grid Inverter/New. Some of them may be not easy to define, such as the efficiency curve. But others could be obtained through the specification.Good luck.
André Mermoud Posted January 22, 2013 Posted January 22, 2013 When in "Tools" / "Inverter" database, you have a button "New". The easiest way: choose an existing inverter (analogous to yours), modify the parameters according to your datasheets, and save it under another name, thus creating a new component in the database. The filename is the "primary Key" of each database element. I have taken the convetion to define it as "Manufacturer_Model.OND".
