When I import a 3D near shading scene from Helios3D, PVsyst (version 6.72) changes the azimuth angle from 0° to 1°. I can manually change it back to 0° in the Orientations menu and Near Shadings menu, but when I run the simulation again, PVsyst changes it back to 1°. I am assuming that this is a cosmetic issue in PVsyst and the actual calculations are not affected since the shading table appears to be the same, however, need confirmation that this is the case.
  • 2 weeks later...
maybe it is also an issue raised by "true north vs. grid north" pls see here: https://en.wikipedia.org/wiki/Grid_north
  • 4 years later...
Follow these steps after importing the scene  "Near Shading" Button >>> "Construction/Perspective" >>> "Edit" >>> "Rotate whole scene" .... Enter the exactly degree amount you want to rotate. Please use the opposite "+/-" sign before the degree. Ta da... the azimuth problem is solved
