again problem with SMA STP
klerindias
i not giving up and trying with sma stp assymetric inputs.
I will show each step, please tell me if i did anything wrong.
First i added inputs for each sma stp, input A and input B.
Then i tried to make easy setup to use this inputs with different numbers of modules.
http://img687.imageshack.us/img687/9405/smastp1000tla4.jpg
So i did two subfields:
First subfield with input A with 2 strings 22 modules in series.
So we can notice i got somehow 2 inverters not just 1. Did i do good input A setup?
http://img138.imageshack.us/img138/8839/smastp1000tlb1.jpg
And I did second subfield with input B and 1 string 14 modules in serie.
And here of course pvsys giving warning that input is too small...
http://img12.imageshack.us/img12/1899/smastp1000tlwarning.jpg
I can live with it if this gonna work BUT:
http://img600.imageshack.us/img600/8475/smastperror.jpg
I can not do any simulation!!
What i did wrong this time?
Here is example from sunny design with same setup.
http://img713.imageshack.us/img713/3418/sunnydesignteststpsma.jpg
Please help.
In your first step, you have defined:
- 4 inputs (which are just the connections)
- No use of MPPT. You should check "Multi-MPPT capability" and then define 3 MPPT inputs here.
- Save the inverter under another name.
After that you can define a sub-array with 2 MPPT inputs (2 strings) and the second one with one MPPT input, and everything should be OK.
Hello
I did this way:
My problem was that i got 107 modules 240W, and want to use SMA STP 12000TL.
I splited inverters like this:
Inverter 1:
Input A1: 21
InputA2: 21
InputB: 12
Inverter2:
Input A1: 21
InputA2: 21
InputB: 11
I made one inverter SMA STP 12000TL A4 with 3 "string inverter" and 3 Multi-MPPT
I made second inverter SMA STP 12000TL B1 with 3 "string inverter" and 3 Multi-MPPT
I made 3 sub fields
First subfield
I used option "Use multi-MPPT features" and putted 4 string with 21 modules , SMA STP 12000TL A4
Second subfield
I used option "Use multi-MPPT features" and putted 1 string with 12 modules , SMA STP 12000TL B1
Third subfield
I used option "Use multi-MPPT features" and putted 1 string with 11 modules , SMA STP 12000TL B1
So i did same 2 inverters, just different names and then i could make simulation.
And only in this case i could run simulation.
When i tried to do 2 inevrters with ratio "string inverter/Multi-MPPT capability" 3/3 and 1/1 it didnt allow make me simulation
Is it good what i did?
  • 2 years later...
