kp_optarel Posted February 16, 2018 Posted February 16, 2018 Greetings,I recently got the latest update of PVsyst 6.6.8 but I encounter a problem when printing my simulations with PDF Creator.There's a pop up that says : There is an error with the selected printer. If I close PVsyst, PDF Creator shows up but it only prints the first one or two pages when I have five of them.I tried to update PDF Creator but the problem is still there. So for now, I use the copy to clip board function.I'm on windows 7. Has anyone met the same problem ?Thank youEdit : I solved my problem by updating PDF Creator to the 3.1 version and rebooting my computer.
Sylvain Pepoli Posted February 23, 2018 Posted February 23, 2018 Hello,Thank you for the edit giving the solution to your issue.Did you try to directly use the "Print to PDF" button from the report ?
kp_optarel Posted February 26, 2018 Author Posted February 26, 2018 Hi,I usually go to detailled results --> Print. Then I have the window where I can select the printer I want to use and I click on print again. Then PDF Creator normally shows up but this time, there's the error message I described before.Before updating PDF Creator, I tried to use the "Print to PDF" button. But if I wanted to use this way, only the 1st page of the report is created.I hope this helps you :)
