Hi PVsyst team,
I have a couple of doubts with the PVsyst V6.26 - PREMIUM PREMIUM and I hope you can help me.
Doubt 1: I am trying to model a tracking PV system with a N-S axis orientation (watch case1 of image 2) but I don't know if the "Pitch" parameter which appears in the field "Orientation" (watch image 1) refers to the distance between trackers (watch the case 1 of image2) or the distance between panels whithin a tracker structure (watch case 2 of image 2).
Doubt 2: I don't find an option for the tracking system with one axis oriented N-S in the Construction/Perspective tool (3D Shading). (Watch image 3).
I'll be verty grateful if you can help me,
Best regards,
Simón Aguilera
  • 2 weeks later...
1) Pitch in PVsyst is centerline to centerline of the tracker axis.
2) I think tilted axis means the entire axis is tilted ( not the individual modules on the axis)
You might want to try the other options with 2 axis.
#1) In a N-S tracker system, pitch is the E-W distance from post to post for the tracker. This can be verified in the shade scene once constructed.
#2) The option is called Tilted Axis to select N-S tracker.
