String Inverter
FICHTNERINDIA
How to design string inverter in PVsyst?
String inverter shall have minimum efficiency of 97%.
Design Ambient temp. is 50 deg C.
Suppose 25 modules are in series in a string and 10 strings are in parallel. Then, 1 inverter is required. However, I am confused how to design string inverter for each of the 10 strings. Please help!
  • 2 months later...
If I understand your question properly, you will have 10 strings in parallel.
Choose a module, and note it's power rating (say, 300W).
Decide how many modules you are going to use (say 100). Then decide the strings (10).
Your total power is 300x100 = 30kW. So you need inverters enough to cover 30kW. You can select one 30kW inverter, three 10kW inverters, or any other combination that works.
Good luck!
