Several Orientations with Optimizer
CivilNJ
I am trying to understand/run an analysis of a rooftop system where the designer is using SolarEdge 33k US Inverter with P700 Optimizer and Hyundai HiS-S350TI Modules .
Using PVsyst version 6.63
The design jumps to two different tilt scenarios on one string and I believe that I have set it up properly but it seems to be unable to run the Simulation because one of the Sub-Arrays is too small (inverter is strongly oversized message). I have attached two screen grabs in the hopes that someone can direct me properly with this. Am I missing something or is this even possible? I just got off the phone with SolarEdge and the multi-tilt option shouldn't be an issue. I must be missing something in the PVsyst program.
Link to comment
Share on other sites
It seems like there is more to this than simply turning on the Fractional Inputs. I had originally tried to analyze this with only one string on multiple tilts - oops. Now including all 3 strings to this inverter. I just haven't done anything this complex before. When you enter the planned power, it sets the Fractional to 0.1 - does that need to be set to the actual fraction of the array for each segment?
Orientation parameters
Field type: Several orientations
2 orientations: tilt/azim = 5°/0°, 18°/0°,
Compatibility between System defintions
Orientation #1 tilt/azim = 5° / 0°
3 sub-arrays PNom = 37 kWp, modules area = 207 m²
Orientation #1: No Shading field defined
Orientation #2 tilt/azim = 18° / 0°
4 sub-arrays PNom = 41 kWp, modules area = 227 m²
Orientation #2: No Shading field defined
System parameters
7 sub-arrays defined
Sub-array #1 5 Degree String 1
Orientation #1Tilt/Azimut = 5.0° / 0.0°
PV modules: 1 strings of 34 modules in series, 34 total
Pnom = 350 Wp Pnom array = 12 kWp, Area = 67 m²
Inverters (33.3 kWac) 3 MPPT inputs, Total 10 kWa
Sub-array #2 18 Degree String 1
Orientation #2Tilt/Azimut = 18.0° / 0.0°
PV modules: 1 strings of 30 modules in series, 30 total
Pnom = 350 Wp Pnom array = 11 kWp, Area = 59 m²
Inverters (33.3 kWac) 1 MPPT inputs, Total 3 kWac,
The inverter power is strongly undersized.
Sub-array #3 18 Degree String 2
Sub-array #4 5 Degree String 2
PV modules: 1 strings of 36 modules in series, 36 total
Pnom = 350 Wp Pnom array = 13 kWp, Area = 70 m²
Inverters (33.3 kWac) 2 MPPT inputs, Total 7 kWac,
Sub-array #5 18 Degree String 3a
PV modules: 1 strings of 32 modules in series, 32 total
Pnom = 350 Wp Pnom array = 11 kWp, Area = 63 m²
Sub-array #6 5 Degree String 3
Sub-array #7 18 Degree String 3b
PV modules: 1 strings of 20 modules in series, 20 total
Pnom = 350 Wp Pnom array = 7.0 kWp, Area = 39 m²
Shading scene parameters
No shading scene defined
Link to comment
I am definitely missing something and am under the gun now.
Throw out my original screen grabs. I now have 7 separate breakdowns of the original data.
My strings/tilts are as follows:
String 1: 33 modules @ 5 degrees
String 1: 6 modules @ 18 degrees
String 2: 14 modules @ 18 degrees
String 2: 26 modules @ 5 degrees
String 3: 20 modules @18 degrees
String 3: 18 modules @ 5 degrees
String 3: 2 modules @ 18 degrees
I have two Orientations set up - 1 for 5 degrees and one for 18 degrees
I have 7 sub-arrays representing each of these string parts noted.
I have fractional inputs checked with the total or all seven = 1.0 inverter (0.2, 0.1,.., etc.)
I have tried setting each sub-array to the proper orientation for that section and tried it with the Mixed #1 and #2 settings.
System parameters
Am I missing something very obvious or it this not the correct logic?
Any assistance appreciated.
Jim
Link to comment
