karaokemasta22 Posted September 19, 2017 Posted September 19, 2017 Hello,I have been having this trouble with PVsyst where when I open a .SHD file from another project or someone sends me a file, the near shading settings change, especially when defining the arrays.I am not sure why this does this. I have to sometimes readjust all the sheds.
dtarin Posted September 19, 2017 Posted September 19, 2017 (edited) Yes, this is annoying. It has to do I think with the default settings for module spacing. Best case is to set it to zero in hidden parameters, so that when you import a project or shade scene, it doesnt rearrange the table by changing the table size. If the scene was set with .01m, and your default is .02, there wont be enough room in the table, so itll switch orientations and make number of modules accomodate the table. It would be nice if PVsyst automatically adjusted, or had an option where hidden parameter settings dont override the shade scene like that. Edited September 20, 2017 by dtarin
karaokemasta22 Posted September 20, 2017 Author Posted September 20, 2017 Thanks a bunch! I will give this a try. :D
Sylvain Pepoli Posted September 21, 2017 Posted September 21, 2017 Hello there,We have identified and fixed an issue happening when loading shading scenes, modules layout parameters were not read properly and therefore PVsyst was getting an automatic layout everytime.This will be fixed in version 6.65.
karaokemasta22 Posted September 26, 2017 Author Posted September 26, 2017 Thank you! I appreciate this update.
