Intertechne Posted March 31, 2017 Posted March 31, 2017 Dear PVsyst experts,To perform a DC:AC ratio analysis which would be more accurate? To increase the DC fields (number of modules) ou to reduce the AC power (number of inverters) ? When i choose to reduce the AC power and in order to perform DC:AC ratio steps i use inverters with reduced power, for example, 10 inverters of 100 kW and therefore reduce the number of inverters to make the steps of DC:AC ratio eventhough the actual inverter is only one of 1000 kW. I noticed that depending on the type of inverter the clipping loss will change significantly when using, for example, 10 inverters of 100 kW instead of 1 inverter of 1000 kW eventhoug their efficiency curves and limitation curves are very similar.Does anyone have a suggestion why the difference? What would be more appropriate?Thanks in advance
André Mermoud Posted April 3, 2017 Posted April 3, 2017 Please check that you don't have a too high Vmpp value. See the FAQ Why the overload loss sometimes increases significantly without reason ?
