Rafael Santos Posted February 7, 2017 Posted February 7, 2017 Hi all!The "optimization tool" option could be a very interesting tool to find an "optimal" pitch for a given project, but it does not seem to work with tracking systems when I change the pitch parameter, I don't know if I'm doing something wrong or if it's a bug. It gives always the same system production.Someone had the same problem, but he/she commented on somebody else's topic... I think it is a good idea to open a separate topic about it.And just to be clear, I tried a lot of different pitch values, from very close to far, so It is not that the pitch values are already too high! ;) Regards,Rafael
Soldnerkugel Posted February 8, 2017 Posted February 8, 2017 Maybe it is an issue somehow related to the maximum tilt angle in case you should use a tracking system with "backtracking" option?
Rafael Santos Posted February 8, 2017 Author Posted February 8, 2017 Maybe it is an issue somehow related to the maximum tilt angle in case you should use a tracking system with "backtracking" option? Sorry, I couldn't understand your question... I allways use backtracking in my simulations. Maybe you've got a point, since the optimization tool seems to work allright with fixed modules, but I didn't understand exactly what you meant. Could you please explain?Thank you very much for the help!-Rafael
Soldnerkugel Posted February 8, 2017 Posted February 8, 2017 Backtracking shall avoid shading on your pv-panels, so you define a limitation on the angle of tilting the pv-panel at a certain pitch. Maybe this limitation is kept for also for other pitches.If you increase the pitch you could change also this limitation, you could allow a higher tilt (because there's more space between two adjacent rows of racks), so you could benefit from a gain in incoming irradiation on your array at low solar zenith angles. ...but if the limitation will stay the same, there'll be no gain in incoming irradiation. Only you could benefit maybe from less "near shading" losses. (This now depends on your location and the specific amount and hourly distribution of irradiation, if you should use an SAT with an east-west tracking the gain from less "near shading" losses most probably should be very low. Locations far away from equator should benefit - if the irradiation at this locations early in the morning and late in the evening would not be that low. Locations (relatively) close to equator normally show a significant irradiation already early in the morning / late in the evening but they probably also will show no benefit or only a small benefit as the sun much faster reaches high solar zenith angles than at locations far away from equator.This maybe could be an explanation, but:1. the information about your project is very limited and still there are maybe parameters of interest which could affect the result that I do not know.2. I yet did not use the "PV Syst optimization tool" as I do have my own one since 2011, which shows also some other results that are of interest when it comes to optimizing a solar farm. ;) ...so this is only an assumption what could be
Loract Posted December 12, 2024 Posted December 12, 2024 On 2/7/2017 at 10:05 PM, Rafael Santos said: Hi all! The "optimization tool" option could be a very interesting tool to find an "optimal" pitch for a given project, but it does not seem to work with tracking systems when I change the pitch parameter, I don't know if I'm doing something wrong or if it's a bug. It gives always the same system production. Someone had the same problem, but he/she commented on somebody else's topic... I think it is a good idea to open a separate topic about it. And just to be clear, I tried a lot of different pitch values, from very close to far, so It is not that the pitch values are already too high! ;) Regards, Rafael I also recently implemented software from https://oboard.io/okr-board-for-jira into my business, which improved the process of setting and tracking tasks. It is useful. Hi Rafael, I understand your frustration with the optimization tool not working as expected. It's indeed a useful tool when it works correctly. Here are a few things you could try: Check the Tool's Documentation: Ensure you're following the correct steps and parameters for the optimization tool. Simplify the Model: Try simplifying your model by reducing the number of components or constraints. Sometimes, complex models can hinder the optimization process. Experiment with Different Initial Values: Starting with different initial values might lead to different optimization results. Adjust the Optimization Algorithm: If the default algorithm isn't working, try experimenting with other algorithms or tweaking their parameters. Consider a Different Optimization Tool: If the built-in tool continues to be problematic, you might want to explore other optimization software or libraries. If you're still encountering issues, consider posting a more detailed description of your problem to a specific forum or community related to your field. You might get more tailored advice and troubleshooting tips. Remember, optimization is often an iterative process. Don't get discouraged if it doesn't work perfectly the first time. Keep experimenting and refining your approach. I hope this helps!
