Please help me find my mistake with calculation of Shading limit angle or give formula for it.
For horisontal basis I receive formula :
θ = arctg ( sin β / (Pitch/L - cos β))
where β - Tilt of table
L width of table = const = 3.3 m (2 portrait modules)
My calculation for θ (Pitch, β), degree :
θ (5, 30) = 54.7 PVsyst : 38.0
θ (5, 36) = 64.0 PVsyst : 40.1
θ (9, 30) = 17.1 PVsyst : 15.2
θ (9, 36) = 20,4 PVsyst : 17.2
θ (11, 30) = 12.7 PVsyst : 11.5
θ (11, 36) = 15.2 PVsyst : 13.2
looking forward to hearing from any who knows why I receive different results.
Regards,
Ruslan
  • 3 weeks later...
Dear unilhexio,
Our formulas is same :
L*sin β / (Pitch - L*cos β) = L*sin β / L ( Pitch/L-cos β ) = sin β / (Pitch/L - cos β )
Please give another variant. But if You and me have same formulas, error in the PVsyst?
Dear Rusian,
Your formula is the following:
And the one I obtained is:
θ = arctg ( L*sin β / (Pitch - L*cos β))
These are not same.
Be aware that you are subtracting 'L - cos β' (this is, a distance in meters and cos β with no units)...
I have tested my formula and it leads to exactly the same result than PVsyst do.
Regards.
Dear unilhexio,
Our formulas is same. My dont has expression L-cos β. Only Pitch/L - cos β.
θ = arctg ( sin β / (Pitch/L - cos β)) = arctg ( L*sin β / (Pitch - L*cos β))
and gives same results (Im checked out now)
Please give me your arguments and results will be same. For example I'm calulated :
L=3.3 m
Pitch = 9 m
β = 36 degree.
for my formula θ = 20.38 dergree, for yours formula θ = 20.38 degree, PVsyst gived 17.2
If Yours result is different, please write me to eynesr@gmail.com, I will send You my excel - file with all calculations.
Best regards,
Ruslan
Dear Ruslan,
I think you are doing something wrong.
Our formulas are different. You are substracting cos β (it does not have units) and L (its units are meters).
I think the following image can clarify the problem:
https://s28.postimg.org/4ufl2kv8p/20170110_173439.jpg
For your example (β=36 and L=3.3):
Then:
θ = arctg ( 3.3*sin 36º / (9 - 3.3*cos 36º)) =
= arctg ( 3.3 * 0.58779 / (9 - 3.3 * 0.809) =
= arctg ( 1.93969 / 6.33024) = arctg (0.3064) = 17.036º
If you do not find the problem, then tell me and I will write you an email to receive your excel calculation.
Are you converting the tilt angle into radians in excel calculation?
Regards.
Dear unilhexio ,
I'm found error. Its convertation rad-grad and grad-rad. I'm forgot multiply Pi() for grad to rad.
and our formulas and pictures is same :
θ = arctg ( sin 36º / (9/3.3 - cos 36º )) = arctg ( 0.58779 / (9/3.3 - 0.809))= arctg (0.58779 / 1.91827) = arctg (0.3064) = 17.04º
Many thanks for Your time,
Best regards,
Ruslan
Dear Ruslan,
I am glad we found the mistake. It is very common to skip the radians conversion to operate with trigonometric operators in excel.
Best regards!
