shading and tracking
If I understand well, you have put modules on trackers, with a tilt angle of 6° with respect to the horizontal axis.
With this configuration you should use the configuration "Tracking 2 axis, frame NS". And here you have to "fix" the module tilts by defining Min tilt/frame = Max tilt/frame = 6°.
NB: Don't use the Backtracking option: it is not suited for that: it concerns the tilt on the frame only.
Link to comment
Share on other sites
  • 1 month later...
  • 4 months later...
Dear Sirs!
Could you explain me how program PV Syst calculate:
- shading from nearest string of solar panels,
- optimal distance between strings.
My problem is: program shows me that shading area is more then area for solar panels, what shall I do in this case?
Sincerely yours,
Michael
Link to comment
