May i know how to adjust 2 parameters below to obtain the higher performance ratio at the output of inverter.
1) PV loss due to irradiance level (cost 0.5% efficiency loss)
2) PV loss due to temperature (cost 9.5% efficiency loss)
In my simulation, the thermal parameter i set to "free" mounted modules with air circulation. The geographic site at Kedah, Malaysia.
There is no really explicit parameter for these losses: these are a result of the simulation.
- The irradiance loss is related to the low-light performance of your PV modules. Which is itself dependent mainly on the Rserie defined for this module.
Please see our FAQ How should be the Rserie value specified ?
- The temperature loss is related to the heat loss factor U (normally 29 W/m2k for a "nude" module, i.e. row arrangement), and the temperature behavior of the PV module (muPmpp factor).
You should not modify these values without solid reasons.
  • 6 years later...
Posted (edited)
Hi
Could you explain how can I adjust the heat loss U factor if I have enough data from many years of temperature sensors on the ambient and panel temperature?
Thank you
Edited by Cohend555
