dcormode Posted August 19, 2016 Posted August 19, 2016 There is a somewhat odd site for which I am building an "as-built" PVsyst model for the owner. The site is comprised of single axis trackers which are not built with the axis of rotation along the N-S line. The axis is horizontal, but with an azimuth about 12 degrees off the N-S line. It is as though the builders constructed the site so that the axis was aligned to magnetic north rather than true north. I am certain this will make some difference in annual production.I *think* that manually rotating the arrays in the shading scene so that they have a non-zero azimuth is the correct approach. However the azimuth setting in the orientation section is always zero and cannot be changed. Looking at hourly data, it is not clear to me if my solution is correct.Please advise as to how I should model this.
André Mermoud Posted August 31, 2016 Posted August 31, 2016 This is indeed a difficult point in the PVsyst definitions. Please see our FAQ How is defined the tracking axis azimuth ?
