mmwerner Posted August 3, 2016 Share Posted August 3, 2016 I have a 3D scene involving maybe three dozen rows of single axis trackers, with a handful of utility poles not far to the south. When I run the model, I can see the shadows from the poles passing across large portions of the array. However, these poles only reduce the specific production by 3 points, which seems absurdly small for a shadow that covers modules along multiple trackers at once. Particularly with these shadows being counted as 100% opaque, shouldn't multiple strings be taken offline fairly consistently? Wouldn't that result in a greater impact? The only potential conclusion I have come to is that the simulation may not be accounting for the whole string going down, and is only factoring in the impact that the shadow has on that individual module. Does anyone have more information on this?Thanks! Link to comment Share on other sites More sharing options...
André Mermoud Posted August 9, 2016 Share Posted August 9, 2016 The "linear" shading loss (irradiance deficit) is probably not very important in your case. If you want to evaluate the electrical losses, you have to use the option "Shadings according to Module strings", or "Module layout". Link to comment Share on other sites More sharing options...
