azizsye1 Posted September 5, 2012 Share Posted September 5, 2012 Hello, I am trying to run a simulation using a Seasonal Tilt of 5 Degrees during the summer and 10 degrees during the winter. When I set up the orientation parameter I can select this from the drop down menu and it sets it at those requirements. When I then click on Near Shading it reads to me that I have to create a a active PVsyst area of 13m^2 and so I click on Near Shading to add panels but I dont know which panels to add. I have tried adding PV Panels in Sheds but then I have to end up updating my orentation settings. Im not quite sure what to do. Please let me know if you have done this before. Thanks. Regards,S.A. Link to comment Share on other sites More sharing options...
Rapha123 Posted September 12, 2012 Share Posted September 12, 2012 When you go into the near shadings tab it should give you a warning that you can't define near shadings with a seasonable adjustable array.My suggestion would be to run two simulations, one at each tilt angle. Then take a yearly average using the monthly values corresponding to each tilt angle. Link to comment Share on other sites More sharing options...
azizsye1 Posted November 15, 2012 Author Share Posted November 15, 2012 I apologize for my late response. But thank you for your answer, it did the trick. Link to comment Share on other sites More sharing options...
