Search the Community
Showing results for tags 'power factor'.
  • Search By Tags
  • Search By Author
Content Type
Forums
    • Latest news
    • PVsyst main changes
  • FAQ (read only)
    • Meteo data
    • PV Components
    • Shadings and tracking
    • Simulations : parameters
    • Simulations : results
  • Your questions about PVsyst
    • How-to
    • Problems / Bugs
    • Meteo data
    • PV Components
    • Simulations
    • Suggestions
    • How-to
    • Problems / Bugs
    • Suggestions
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
About Me
Found 3 results
  1. Grid Power Limitation: The option "Account as separate loss" in the menu grid power limitation may pose a problem when used together with a power factor. However the loss diagram and .csv simulation output are not affected. Hourly Graphs may be affected upon context: When the simulation variables EReGrid, EApGrid and EGrdLim are not explicitly saved, it can trigger wrong calculations of the reactive and apparent energy in the hourly plots (too high values for both). Saving those variables in the menu "Advanced simulation / Hourly data storage" solves the issue: Until the option is fixed in a future version, the software will display a warning when both options are used together.
  2. Hi, I configured PF=0.95 in Energy managment but when I check the Sytem design the inverters were not affected by it and so Ratio dc/ac is calculate as PF=1.
  3. Hello, I've recently discovered that entering a leading power factor still shows as a lagging power factor in the report. I've verified this across multiple projects. Let me know if you have any questions.
