david.zar
  1. Hi, Is it possible to use "Backtracking" and "Irradiance Optimization" in the same simulation?
  2. Hi, We have the following Error in the Batch Simulation. We use the file created by PVsyst
  3. Hi, We would like to do several variants with bifacial and not bifacial modules. When we have created the Bifacial variant and we try to create a not bifacial simulation, the software says that the project has a bifacial structure and we need to change the module.
  4. david.zar
    Tracker
    Hi, We have real data in 1 axis tracking system. Is it possible to import this information into .csv PVsyst format?
  5. Hi, I'd like to know if when a scene is drawn, it is necessary to put the field in its height of installation. For example, Z= 0 it's ground reference and if we install the tracker with a distance of 2 m from the ground we need to put Z=2 m. Thanks
  6. André, If we selected in "Miscellaneous tools" one option, Does the program calculate the temperature derating with the meteorological information if the .ond has the information?
  7. Hello, I would like to propose a suggestion about the "Unavailability". If it's possible, we would like to add a possibility that put a fixed % for all the year. For example, if you put 1% of unavailability, this % it was applied to the 8760 hours. On another hand, we are seeing several errors when the program saves the preferences (printer forms header lines, output file preferences..)
