MicheleANE
Everything posted by MicheleANE
Dear PVsyst team, We often run large and complex simulations in which the shading computation (even using fast table method) takes up to several hours. Often we leave the machine working at night and get the results in the morning but we have no way to know when the computation actually ended. This info would be helpful for the future, so we can know in about how long we could run a new variant with similar shadings. While the computation is running, we can see how long it took so far so, when finishing, it would be enough to keep the last value of elapsed time on screen somewhere. Now it closes with the progress bar and there is no way to retrieve it (correct me if wrong). Would it be possible to add this functionality in a future patch? Best regards
Hi, At ANE (my company www.ane.tokyo) we developed a simple web tool to convert the data from Monsola 20 to PVsyst standard format. You can find it in the PVsyst help if you search for "NEDO" or at the following URL: https://www.ane.tokyo/NEDO-PVSYST/index.html Please feel free to contact me if you need any more help or clarification. Best regards
Hi, We were trying to decrease the file size of the report for a very complex simulation by decreasing the resolution setting to the lowest possible but the exported file doesn't seem to change at all even when setting it to max or min values. Is this not the correct setting? Thank you and best regards
Dear Eric, 50k polygons are really too few for large power plants on complex terrain. We also often work on 100MW+ projects and it would be a life-saver if the terrain polygon number would not influence the speed of the software as a whole. Is there really nothing that can be done for this? We have software that can do real-time rendering of millions of polygons... Please consider this, best regards
Dear PVsyst team, We usually simulate quite complex 3D scenes with many different orientations and in some cases there is only 1 or 2 arrays for an orientation. In these cases PVsyst doesn't allow us to simulate the bifacial part because the pitch is not omogeneous enough or it is 0 in the 3D scene. I tried using the "Pitch defined by user" and "Number of Sheds defined by user" parameters and defined parameters similar to other orientations because in the 3D these arrays are close to other arrays with similar parameters. Even doing this the software doesn't let me simulate. Is there anything I can do to run it anyway? Would be possible to change this behavior so in case we defined the pitch and sheds number as "defined by user" the simulation will use this parameters disregarding the actual 3D? Best regards
Hello again, This seems to be solved. It was probably on Meteonorm side, sorry. Best regards
Hello, Both using version 7.4.8 and 8.0.3 the import of Horizon line from Meteonorm API doesn't work. It seems the API is replying with "failed". Best regards
Hi, I am trying the ver8 now and noticed that, after creating a 3D scene and running the shadings calculation by clicking the Table button, when I close the table window, the software tells me to press table again. Also, if I ignore this and close the Near Shadings window it tries to run the calculation again and then, even after running it here, when I press Run simulation button, it runs it again. For now I'll just skip the first 2 times and run it in the end so it gets saved but please advice. Best regards
Shading losses applied after calculation of GPOA
MicheleANE replied to jonipa's topic in Problems / Bugs
Hi, What you measure on site should be as close as possible as this GlobInc. Meaning that pyranometers should be installed with the same orientation of the arrays and they should receive no shading. Of course you can't avoid Far shadings from mountains and that is why, when comparing simulation and measured data, you should exclude that loss. Hope this helps, best regards -
Hi, Sorry to intrude this topic. We also often Face this issue. While it's possible to adjust the loss by changing the length, the end-user will read on the report a value for the thickness that is not the real one and often ask us the reason. Would it be possible to allow custom sizes or maybe allow to define other sizes in a separate file? Best regards
Template which contains all the info for same type of projetcs.
MicheleANE replied to ShivamPandey's topic in Suggestions
Hi, While there is no template system, you can make a template-like variant in a project and then when creating a new project you can import that variant as a base. Hope this helps, best regards -
Dear Linda, While it's true you can import GTI data this way, I believe PVsyst will once calculate GHI from this imported GTI and then calculate GTI internally. This 2 GTIs will probably differ by some value. I think Florent was asking if it's possible to keep the exact values as imported. Of course correct me if I am wrong, best regards.
Hi, When comparing simulated data with measured one, it would be great to have the possibility to input degradation loss monthly and have the software use those numbers as they are (no averaging). Another option would be to have the degradation loss actually change during the year. Example: Starting degradation set as 0.5%, Yearly degradation loss set as 0.365% -> each day increase the degradation by 0.001% so -> 0.501%, 0.502%, ... Best regards
Polystring option (mixed orientation within a string)
MicheleANE replied to julmou's topic in Suggestions
Hello, Just to add some to this. This effect is also present, in a more limited form, in large scale plants on hilly terrains. In most cases small tables are used to better adapt to the terrain and strings are made up of several arrays. In these cases there will be a mismatch of current because of the different POA irradiation in these several tables. It would be fantastic if this could be calculated in PVsyst. Best regards -
Hi Michele, Thank you for your response. It is nice to know this is being given thought. Couldn't ask for more. Best regards.
Hello, Any news about this? 2 decimals are more than enough. Just, please make it so the parameters inputs are 2 decimals as the results and that those 2 decimals are kept the same for losses that are directly calculated using those parameters (ex.: soiling loss). Also, recently I noticed that the mismatch loss keeps the input value only on the first run of that variant. If ran twice, it will sometime change (usually x-0.01%). Best regards
Hello, @dtarin We usually don't use the internal tool to fit arrays on terrain but this could be an idea for a workaround: Instead of using trackers from the beginning, fill the areas with fixed tilt arrays of the same size of the trackers and use an azimuth that gives you the same shape of the trackers (SN axis -> 90 degrees azimuth for fixed tilt) and tilt equal to the max tilt of the trackers. After positioning them convert them to trackers with the internal tool and they will keep the SN slope too. Best regards
Thank you for the prompt response. I perfectly understand your point about accuracy and agree. It's more about coherence and being able to show that we used the input values as requested. It would actually be fine if all losses and inputs were fixed at 2 decimals without other options as long as they were all compatible. Thank you in advance for your support and best regards.
Hello, We are able to display the report using 1 to 3 decimal places but, in several places of the software, the input is limited to 1 or 2 decimals (soiling, aging, etc). Often we are requested to run simulations with input values calculated separately and, as they are often given with 3 or more decimals, it would be nice to be able to keep the same precision in the input and output. This is especially true for losses that just use the input value. These should not be rounded more than the report precision requires. Best regards
Thank you for the prompt response. I understand that the effect is very low. The problem is the consistency of the rounding. It would be fine if it always rounded to 0% or as normally if >0.05 then 0.1, if<0.05 then 0 or also always to 0.1 Also I don't really see the need of rounding these numbers. Wouldn't be even easier to just keep them as they were input? Sorry for being pedantic but we were asked this by customers and we are not able to give them an answer. Best regards
Hi, I was doing several simulations of the same project using GHI data measured on site on a monthly base and only changing the soiling setting and I noticed an inconsistency in the resulting loss. In some months the measured soiling loss was under 0.1% (ex.: 0.06) and without any visible reason the resulting loss becomes 0.1% or 0%. This doesn't even depend on the input number being over 0.05% or not. I had some months with 0.02% setting giving 0.1% loss in the diagram. I understand this is a very little difference but I have no explanation to give customers when asked for. The best solution would actually be to just use the setting number as it is without rounding, both in the settings report and in the loss diagram. Thanks in advance for your time and best regards. Michele
Hi, You could also make an experiment in PVsyst: Using just a table with the correct size and tilt, place it facing backward as if it was the rear face of the module. Then run 2 simulations, one with the net and one without it and see the difference in shadings. It's still not real but could give a guide for your assumptions. Best regards
Hi, Sorry for intruding in an ongoing thread. I would also consider changing the order of far shadings and Global incident in coll. plane effect. Physically, light is firstly blocked by mountains and other obstacles and then received by modules at their tilt that increases or decreases it compared to GHI. Also, far shadings should probably be excluded from the PR calculations because, in reality, the pyranometers installed on site will only get the irradiance left after far shadings are subtracted. In some cases this is not true, so maybe make it an option. Thanks in advance and best regards
Hello, We had a problem with the Iso-shadings graph. Please see the image below. I would think this occurs when the line would have to go over 90 degrees that is the display limit for this graph, and instead of just disappearing or changing the display, it drops down to 0. On another note: please make possible to set defaults for all reports, maybe in advanced settings. Recently the output units started switching to GWh but for projects going on for some time, we would like to keep them at MWh units and so we have to change this back very time we output a report. This takes time because the report takes some time to update every time we change something and also makes it easier to make mistakes and output reports with different units. Best regards
Hello, The email I sent wasn't about the report but about a strange behavior when changing project settings for orientations detecting. I understand that we don't pay for support but we pay the software and therefore any bug and its solution becomes your responsibility. Your answer didn't provide any constructive info so please, once more, advice on how to solve these problems because our work depends on it. Best regards
