MicheleANE
1 Follower
About MicheleANE
  1. Dear PVsyst team, We often run large and complex simulations in which the shading computation (even using fast table method) takes up to several hours. Often we leave the machine working at night and get the results in the morning but we have no way to know when the computation actually ended. This info would be helpful for the future, so we can know in about how long we could run a new variant with similar shadings. While the computation is running, we can see how long it took so far so, when finishing, it would be enough to keep the last value of elapsed time on screen somewhere. Now it closes with the progress bar and there is no way to retrieve it (correct me if wrong). Would it be possible to add this functionality in a future patch? Best regards
  2. Hi, At ANE (my company www.ane.tokyo) we developed a simple web tool to convert the data from Monsola 20 to PVsyst standard format. You can find it in the PVsyst help if you search for "NEDO" or at the following URL: https://www.ane.tokyo/NEDO-PVSYST/index.html Please feel free to contact me if you need any more help or clarification. Best regards
  3. Hi, We were trying to decrease the file size of the report for a very complex simulation by decreasing the resolution setting to the lowest possible but the exported file doesn't seem to change at all even when setting it to max or min values. Is this not the correct setting? Thank you and best regards
  4. Dear Eric, 50k polygons are really too few for large power plants on complex terrain. We also often work on 100MW+ projects and it would be a life-saver if the terrain polygon number would not influence the speed of the software as a whole. Is there really nothing that can be done for this? We have software that can do real-time rendering of millions of polygons... Please consider this, best regards
  5. Dear PVsyst team, We usually simulate quite complex 3D scenes with many different orientations and in some cases there is only 1 or 2 arrays for an orientation. In these cases PVsyst doesn't allow us to simulate the bifacial part because the pitch is not omogeneous enough or it is 0 in the 3D scene. I tried using the "Pitch defined by user" and "Number of Sheds defined by user" parameters and defined parameters similar to other orientations because in the 3D these arrays are close to other arrays with similar parameters. Even doing this the software doesn't let me simulate. Is there anything I can do to run it anyway? Would be possible to change this behavior so in case we defined the pitch and sheds number as "defined by user" the simulation will use this parameters disregarding the actual 3D? Best regards
  6. Hello again, This seems to be solved. It was probably on Meteonorm side, sorry. Best regards
  7. Hello, Both using version 7.4.8 and 8.0.3 the import of Horizon line from Meteonorm API doesn't work. It seems the API is replying with "failed". Best regards
  8. Hi, I am trying the ver8 now and noticed that, after creating a 3D scene and running the shadings calculation by clicking the Table button, when I close the table window, the software tells me to press table again. Also, if I ignore this and close the Near Shadings window it tries to run the calculation again and then, even after running it here, when I press Run simulation button, it runs it again. For now I'll just skip the first 2 times and run it in the end so it gets saved but please advice. Best regards
  9. Hi, What you measure on site should be as close as possible as this GlobInc. Meaning that pyranometers should be installed with the same orientation of the arrays and they should receive no shading. Of course you can't avoid Far shadings from mountains and that is why, when comparing simulation and measured data, you should exclude that loss. Hope this helps, best regards
  10. Hi, Sorry to intrude this topic. We also often Face this issue. While it's possible to adjust the loss by changing the length, the end-user will read on the report a value for the thickness that is not the real one and often ask us the reason. Would it be possible to allow custom sizes or maybe allow to define other sizes in a separate file? Best regards
  11. Hi, While there is no template system, you can make a template-like variant in a project and then when creating a new project you can import that variant as a base. Hope this helps, best regards
  12. Dear Linda, While it's true you can import GTI data this way, I believe PVsyst will once calculate GHI from this imported GTI and then calculate GTI internally. This 2 GTIs will probably differ by some value. I think Florent was asking if it's possible to keep the exact values as imported. Of course correct me if I am wrong, best regards.
  13. Hi, When comparing simulated data with measured one, it would be great to have the possibility to input degradation loss monthly and have the software use those numbers as they are (no averaging). Another option would be to have the degradation loss actually change during the year. Example: Starting degradation set as 0.5%, Yearly degradation loss set as 0.365% -> each day increase the degradation by 0.001% so -> 0.501%, 0.502%, ... Best regards
  14. Hello, Just to add some to this. This effect is also present, in a more limited form, in large scale plants on hilly terrains. In most cases small tables are used to better adapt to the terrain and strings are made up of several arrays. In these cases there will be a mismatch of current because of the different POA irradiation in these several tables. It would be fantastic if this could be calculated in PVsyst. Best regards
  15. Hi Michele, Thank you for your response. It is nice to know this is being given thought. Couldn't ask for more. Best regards.
