André Mermoud
  1. The possibility of defining "heterogeneous fields" (multi-orientations), also with inverters mixed between orientation #1 and #2, is available in PVsyst since the beginning of the version 4. However in the versioon 6.13, you can define up to 8 orientations (and a "mixed" inverter between orientations #1 and #2), without the previous limitations about the mutual orientation difference limit.
  2. For adjusting the maximum output of an inverter, you can simply modify the "Nominal AC Power" parameter in the definition of the device, and save it with under another filename, therefore creating a new device in your database. In your case you will define 1 sub-array with 2 normal 500 kW inverters, and one sub-array with your new 400 kW. Now since the version 6.11, under the button "Miscellaneous tools", you can limit the power of the whole system to a specified value. However the simulation will limit all Inverters identically, to a Pnom = 1400/3 kWax value.
  3. We don't know how to access the Nedo database. Is is public ? Which kind of data does it provide ?
  4. We cannot say anything if you don't mention which kind of wrong data. Please explain.
  5. It cannot be regardless of the irradiance of course. The Maximum power is given by the one-diode model according to Irradiance and temperature conditions. The Pmax is more or less proportionnal to the irradiance (the deviation is this statement is given by the low-ligh efficiency behaviour).
  6. This will be fixed in the version 6.14, to be released on 15/12/13
  7. This may be a limitation of the specifications, but not an operating limitation of the inverter (i.e. the inverter will not limit the current by itself). In this case PVsyst doesn't directly check the current at the inverter input during the simulation. If it is an operating limitation, this will be related to the parameter "Minimum voltage for PNom". This means that you cannot reach the nominal power if you have a voltage lower than this limit. I.e. with lower voltages the possible output power will be reduced, just in order to match this maximum input current: If we define Pnom(dc) = Pnom(ac) / Effic, then Imax = Pnom(dc) / Vmpp For your example, Pnom(dc) = 900 kWac / 0.96 = 937 kW => VmppMin for getting PNom = 937 kW / 1400 A = 669 V. This should be a specification of the manufacturer in the database. You can observe on your file that all your high current values correspond to low MPP voltage.
  8. In the Project's design mode, you have the same pre-sizing tool, which gives an advice about the battery sizing and the required PV array power, based on your Load definition, the desired number of autonomy days (without sun) and the accepted Loss of load. This tool is based on very quick calculations of the system over the whole year, day-by-day (see the FAQ How to size a stand-alone system). However, even in the reality, the battery sizing doesn't depend on the distribution of the load along the day. If you have an autonomy of more than one day, the battery will restitute the same energy whatever the distribution over 24H.
  9. I think you are not aware of the complexity of creating a PDF document within a programming environment. DELPHI doesn't propose tools for creating PDF documents. This would represent a very big programming task, and we have other priorities in the present time.
  10. Please see our FAQ I don't find Li-ion batteries in the database of PVsyst
  11. OK, I have corrected this problem for the next version 6.13.
  12. All the PV modules are specified for a 1000 V voltage limit in the array, by respect to ground (IEC norm). Therefore if you want to do that you should use very special modules, not available on the market. However this inverter is probably specified for using 2 symmetrical arrays (by respect to the ground voltage). In this case you should define the inverter as a "Bipolar" inverter, in the "Sizes" page, "Technology specificities". See the Advanced Energy inverters as an example.
  13. This question is indeed very important. Therefore I have answered it in the FAQ for more visibility (For meteo measurements, should we use a pyranometer or a reference cell ?)
  14. The pyranometer measures the temperature elevation of a blackbody when absorbing the light energy, under a double cupola of glas or quartz (greenhouse effect). Its response is well linear, covers a very large spectrum (flat response until up to 3 micrometers), and has a very good angular acceptance. The accuracy may attain 1-2% with very well calibrated instruments. The reference cell has a short-circuit current well proportionnal to the irradiance (with a little temperature dependence of +0.05%/°C), but it only measures the irradiance in the spectra according to the sensitivity of the PV cell (for crystalline silicon, limited to 1.12 eV, i.e. less than about 1.1 micrometer). Moreover the usual devices are covered by a flat glas, therefore the angular sensitivity is affected by the IAM (incidence angle modifier) reflexion losses. The accuracy is limited by these two phenomena, and cannot be better than, say, 5%. The answer to the question now depends on the use of the results. For measuring the performance ratio (PR) and its stability, the plane-of-array (POA) irradiance is required. The fact that the reference cell behaves in the same way as the array itself (sames biases, spectral and IAM) will provide a good reference for this measurement: the fluctuations of the PR discrepancies will be low. Moreover some reference cells also provide a measurement of the array temperature (by measuring the Voc). However the simulation process is waiting for an "absolute" irradiance input, i.e. without these biases ("meteo" measurement quality). It will include a correction for the IAM (PVsyst neglects the spectral effect for crystalline modules), and the PV module's specified behaviour (on which is based the model) is related to the full spectra (STC are for AM 1.5). Therefore, if you are only interested in the stability of the PV system along the time, the reference cell is well suited. But if you want to provide prognosis, or analyse and quantify the data in more details using the simulation process, you should use a Pyranormeter as reference. Precautions about irradiance measurements The irradiance measurement are rather difficult, and require a great care. - We strongly advise to perform them in the horizontal plane, not the POA (Plane of Array). - The horizontality of the instrument should be carefully adjusted. - The calibration given by the manufacturers is not always reliable. Moreover it may vary along the time (especially during the first years): please carefully check it, if possible periodically, against a reference instrument. - The instrument should be kept clean, without dust. - Usually the datalogger will perform a measurement every some few seconds, and average over a predefined time step. It is very important that this time step is well defined, and namely its stability along the life of the measurement. Otherwise this may induce time shifts when importing in PVsyst. - Check that there are no shades on the instrument at any time of the year (even the diffuse may be affected by shading objects).
  15. Thank you for the suggestion. I note this on our ToDo list, which is already very long ...
  16. Yes of course you can simulate tracking systems without backtracking. However there is no "generic" shading calculation like the "Unlimited sheds" option. You have to define the detailed geometry of your system in the 3D construction tool. NB: for the backtracking, you have also to define the 3D representation: there are no mutual shadows for the beam component, but the diffuse and albedo components are affected by the shading effect.
  17. You are right: the "fast" calculation is done by interpolations in the shading factor table, and I introduced for the version 6 a "slow" simulation where the shading factor is computed explicitely at each step of the simulation. This is a good news that both results are compatible of course... With some very "structured" shadow shemes like row-to-row shadings, there may be little biases with the table interpolation; this new calculation allows to evaluate the effect of this bias. Now the objective of the "Module Layout" definition is to evaluate the electrical mismatch loss. This has to be compared to the calculation "according to module strings", for which as soon as a module is hit by a shadow, it becomes electrically inactive. Both calculation modes give rise to a second "electrical" shading loss contribution, which is mentioned in the array losses. Comparing these losses for both calculation modes should allow to determine the "Fraction for electrical loss" involved in the calculation "according to modules strings", in order to get the same contribution. But the calculation of the "linear" loss contribution - which corresponds to the irradiance deficit on the array - should be about the same.
  18. PVsyst is quite able to model the CIGS modules: you should choose the technology CIS (equivalent to CIGS). Now with these PHOTON data, the specified Number of cells is 88, which leads to a Vmpp value of 0.23 V/cell. This is far below the usual values for CIS technology, the module organization is probably 2 strings of 44 cells in series. When you change this in the "Size and technology" page, please also go to the "Model parameters", and click the default checkboxes for Rshunt and Rseries (=> resp. 80 and 0.373 ohm). Because when trying to adjust the model with the false number of cells in series, PVsyst has fixed erroneous default values for these parameters. NB: During my researchs about modelling, I measured a CIS module during 7 years (one measurement every 10 minutes), and it obeys "perfectly" to the one-diode model (the RMS difference between Measured and Modelled values was < 1%, for any irradiance and temperature conditions over several years).
  19. Some answers, but you should also refer to the help. 1. In a row arrangement, when the bottom cell line is shaded, the concerned string doesn't produce any electricity anymore. The by-pass diodes don't help in this case. As soon as 1/3 of the sub-modules (modules parts protected by a diode) of a string are shaded, the string's voltage is not sufficient to participate to the array power. You can only have a little recovery if the string is alone on the MPPT input, but it may also be below the Vmpp threshold of the inverter. 2. For this reason the "Fraction for electrical effect" should indeed be set to 100% with shed arrangement. 3. The mismatch loss parameter has nothing to do with the shadings effects (see How to define the Mismatch Loss parameter?) 4. See our FAQ What is the "Shading loss according to module strings", and What is the "Fraction for electrical effect".
  20. I can't understand that. When the simulation has been performed with success, you are directly led in the "Results" window, with several options. The main one being "Reports".
  21. You should desable it in the option "Partition in module chains" (icon in the left of the 3D edition), button "Cancel Partition".
  22. PVsyst puts limits to the monthly meteo data, for avoiding erroneous inputs. These limits are applied on the Clearness Index value (Kt) which is the ratio of the measured irradiation to the extraterrestrial one. Therefore Kt is a measure of the transmission of the atmosphere. The limits fixed in PVsyst are Kt = 0.12 (months with very covered conditions), and Kt = 0.82 (very sunny months) (0.8 in older versions). PVsyst also puts a limit to the monthly Diffuse/Global (D/G), established at 0.13 (very sunny days). Usually the values of "normal" meteo data - all over the world - never exceed these limits. However the meteo conditions for Chile are really exceptionnal, and sometimes overcome these limits. You can change them in the Hidden parameters, topic "Miscellaneous".
  23. See our FAQ With my big power plant, the calculation time is prohibitive
  24. The nuVco may either be the result of the one-diode model (and it depends itself on the temperature), or you can specify the value given by the manufacturer. See our FAQ How to adjust the Voc temperature coefficient ?
  25. I will correct it for the next version 5.72
