Toni
  1. Thank you Jérémie for your promot reply...
  2. Hi, I am struggling with a rather simple problem but is it possible to convert a field with fixed tilt tables directly into domes or tracker ? When I change from fixed tilt to domes in the orientation menu and afterwards try to fill out the zone in the 3D scene, the zone is again filled with fixed tilt tables, even if I change the orientation in the 3D workspace.... Is there another approach how to? When I do the changes in the 3D scende first, I get the error that there's no field Any helping advice would be welcome Kind regards, Toni P.S.: I am using PVsyst vers. 8.0.13
  3. Hi, I have the problem that when I select the "Automatic altitude" and set a distance to ground of 0,8m, PVsyst does not apply it. The panels are still going underneath the topology. Does anymone have a solution or advice ? Kind regards, Toni
  4. Thank you for your prompt reply - I will first need to check with my system administrator.
  5. Thank you for your reply - I am using the version 7.4.7 (rev. 37278). When starting PVsyst during booting it's searching fo updates, however when I click on help-> update program I receive a failure messaage (see image below): Do I need to upgrade to new versions to enable updates ? Thanx for any help....
  6. Hi, After I selected the site location (by coordinates), PVsyst still asks for the altitude, even if it's already typed in. It does not import the meteo data and I can not continue. The problem is still present, if I choose other weather data and there's a internet connection (as I've chosen the location from the interactive map). What can I do, to get the meteo files imported ? Thanx, Toni
