Marija Ch.
  1. Hello, I'm working on a PV project that is divided into 9 zones, each with its own grid export limit of 4.44 MW AC. Overpaneling is allowed, so the DC side can exceed this limit. In total, the full plant would have 40 MW AC and potentially more on the DC side. I know PVsyst allows setting a Grid Power Injection Limit at the system level, but I haven't found a way to apply individual grid export limits per zone within a single simulation. Is there a way to simulate per-zone injection limits in one project? Or is it necessary to simulate each zone separately and then aggregate the results? Thanks in advance for your help!
  2. Hello, I have problem creating a Tracking system in Near Shading after the 8.0.0 update. It seems that I can't connect my tables with the orientation I want. For example, I create a tracking orientation as following: In System I select the orientation I want: When I go to Near Shading, before going to Construction/Perspective the Orientation is the right one. The problem shows when I go in Zone Editing. In the Basic Parameters for my Field properties the Orientation I need is not available, even though I have "Create tracking fields" selected, so the program creates a new fixed one for me. If I go to New orientation.. an option for a tracking system is not available. What could be causing this? Can you please help? Best regards,
