Hello,
Thank you for your reply.
I have rade that tread, which you suggested me. As you said in that tread, we can achieve a similar result by creating two separate sub-arrays, one for each orientation, then attribute the strings to the same inverter. In this case, we would have each string with only one orientation. Therfore, PVsyst does not result module mismatch loss in simulation report. However, in real case, we would have mixed orientation in one physical string and module mismatch loss occures.
what would be the another approach to set up string configiration (by considering mixed orientation)?
