n.ragavander
Everything posted by n.ragavander
  1. How to get an evaluation and rub a simulation from this? This design has been made with terrain following trackers using PVcase.
  2. The first one is for azimuth 12° and we are wondering as to how there is a difference of 10 percent in specific production between south and 12°, is there any way to explain this as the loss diagram is pretty much the same only a 2% difference. In all the research articles as well we have an understanding that from 0-40° azimuth change thre is only a 2-5 percent difference in specifc production, so could you explain why this is the case in PVsyst, and also which value should i look into so i can actually justify the 10 percent reduction in specific production? Thank you The below picture is for azimuth 0
  3. Thank you this works well
  4. How do i tackel this issue its a roof with different orirntations is there a possibility to design this?
  5. How do you get exact polygon lengths? How do you toggle the distance function for a more prescise polygon? For example i have a polygon with specific dimensions how can i use these dimensions while constructing it for the near shading analysis
  6. How to solve this issue ?
  7. How do you import a autocad file with the polygons so we can draw exactly to the map for the near shading analysis? is it possible to do this and if so it would be nice to have video that explains that. Thank you
  8. Hello Andre, Im currently working on a sytem that incorportes both EW and trackers and i have an export file from PVcase. Pvsyst is able to read only the tracker system but im unable to run the simulation with both systems present. Is there any possibility to perform a simulation with a combination of systems ? If so it would be great to have a meeting to futher discuss and go through the process. Thank you for your time. Have a nice day.
  9. Okay i understand, Thank you for the clarifications. I also have another question in EW systems PVsyst automatically uses several orinetation option and so a bifacial mode cannot be activated, Is there another way to use the funcion of bifaciality, in theses systems for yiels analysis?
  10. n Comparision to PVsol the specific yield using meternom data in PvSyst shows a significantly higher value for an EW system. What could be the problem here. if there is anyway that we could specify our own orientations after importing the file from PVcase in Pvsyst? It would be of great help if you could hep us out in this as our earlier projects, we have designed using only Autocad requires a specific yield and a specific orientation as these systems are already constructed? Is it possible that you have PAN files for specific solar modules?
  11. How do you actually use the different orientation option for the east-west system? unable to simulate near shading for east west systems? How to do it? Single tracker systems which orientaion need to be selected fot import from pvcase?
