Asyraf
Everything posted by Asyraf
  1. Hi all, Need help on this. I'm currently trying to simulate the generation difference by: 1. Connect 2 different orientations in a string using 1 MPPT 2. Connect 2 different orientations using different input under same MPPT I'm stuck at number 2 as unable/not sure to set the parameters under "system" Below are the specs for the simulation. Inverter: Solis S5-GR3P12K (2 MPPT 4 Inputs) Panel: JA 590W Test 1: MPPT 1 Input 1: 10 panels facing North Input 2: - MPPT 2 Input 1: 20 panels (East + South) Input 2: - Test 2: MPPT 1 Input 1: 10 panels facing North Input 2: - MPPT 2 Input 1: 10 panels facing East Input 2: 10 panels facing South Thanks for the support and advice in advance
  2. Hi all, I'm currently having problem on simulating multi orientation module specifically when creating a near shading 3D scene as it mentioned "The area of the 3D fields is lower than the area of the module defined in the subarrays". I'm not sure if PVsyst didn't allow/unable to simulate for this kind of cases or there's some setting I didn't click on/adjust. My system consist of 3 diff. orientation whereas string 1 facing South & string 2 facing North + West. Under parameter already define with 3 nb of orientations & under subarrays, I only put 2 as if add another subarray specifically for another orientation, PVsyst will detect 1.5 nb of inverters & will cause an error mentioned "The inverter power is strongly oversized". I notice PVsyst detect all 16 module as 1 orientation (string 2) even though on 3D some module already facing diff orientation. Btw this simulation for Residential with below details: Inverter: Solis 3P10K (2 MPPT) Solar Panel: Canadian Solar 455W Nb of module: 29 Module layout: Sub array 1 (13 module) facing South, Sub array 2 (14 + 2 module) facing North + West. Here's another image if I separate all orientation with individual sub array. Hope someone can help on this issue & correct me if there's mistake based on image attached. Thank you!
