Thet
Dear Sir, i am using unlimited sheds feature and bifacial system feature for the first time. We will use 600W bifacial module 5838 sheets. In the Orientiation Parameter, I choosed Unlimited sheds because i would like to use bifacial system feature. But the error appear in the near shading.Please someone explain in the easiest way to understand why is that error appear and how to solve it. Best Regards,
Edit Sub array #2 Mixed Orientation #1and #2= -21 Degrees (50 Modules)&78 Degrees (250 Modules) Total 300 Modules 20 series can not divided to 50 modules and 250 modules So I just set 20 series and 2 Strings for Orientation #1 20 series and 13 Strings for Orientation #2 Connected to 100kW PCS x 2
Is that possible to connect the different orientations in series? We have 3 different orientations as follow: Orientiation#1 = -21 Degrees (50 Modules) Orientiation#2 = 78 Degrees (250 Modules) Orientiation#3 = 159 Degrees (100 Modules) Totals 400 Modules will be distributed to 100kW, 3 PCS and will use 20 series,20 string.So, I set in the system as below : Sub array #1 Orientiation#3 = 159 Degrees (100 Modules) 20 series and 5 strings Connected to 100kW 1 PCS Sub array #2 Mixed Orientation #1and #2= -21 Degrees (50 Modules)&78 Degrees (250 Modules) Total 300 Modules 20 series can not divided to 50 modules and 250 modules So I just set 20 series and 2 Strings for Orientation #1 20 series and 2 Strings for Orientation #2 Connected to 100kW PCS x 2 The problem is System didn’t match with Near Shading. Are there any other options to solve this problem? Thank you for your support always Best Regards,
Dear Sir Thank you for your cooperation always. I am creating PAN File and I would like to know how to calculate Series and Shunt Resistance. I am looking forwards to hearing. Best Regards,
Dear Sir Thank you so much for your support always. Well Noted. Best Regards,
Dear Sir, Thank you for your suppport always. I would like to know how to fix Unregistered I/O error,no 123. The following error appears and CSV file can not be outputed. I am using PVsyst Version 6.7.7. Best Regards, Thet
I am trying to use Ground object feature for a complex solar project which will build over the mountain. My question are Q1: How to use Ground object feature? Q2:What kind of survey data do i need to use ground object feature? Q3:Are there any training video of using Ground object feature? That`s all. Thank you for your always support. Thet
Thank you so much for your support always. It worked well.
I am sorry how to set dummy MPPT. How to use power sharing features
We have four orientations in our system such as 0 Degree,1 Degree,3 Degree and 6 Degree respectively. There are also 5 different buildings as follow; Building#1 0 Degree,78 modules ,3 strings Building#2 6 Degree,624 modules ,24 strings Building#3 3 Degree,208 modules,8 strings Building#4 3 Degree,52 modules,2 strings Building#5 1 Degree,416 modules,16 strings And we are planning to use 4 PCS in our system as well. According to the components specs, we will use 26 series and 53 strings.We want to distribute 26 series and 53 strings to 4 PCS as below. PCS #1 and #2 -> 24 strings PCS#3 -> 11 strings PCS#4 -> 18 strings It seems that we need to mix two orientation of Building#1 and Building #2 to meet 11 strings for PCS#3 and also need to mix Building#4 and Building #5 to meet 18 strings in PCS#4. But I just see that mixing two orientation (mixed orientation #1 and #2) is possible only one time.isn’t it? How to set and mix different orientations and distribute to 4 PCS? Please somebody help to solve this matter ASAP. I am sorry in a hurry. Thank you so much for your always support.
thank you for you reply.It work well.
It can be possibel to create both P50 and P90 userhourly CSV seperately?.If yes,how to create it.Thank you for your support .
CO2 emissions balance page is included sometimes in my report but not included sometimes when I simulate.where could I check its parameters ?now I am using v7.2.18. Thank you ?
