Hi,
I would like to know how to merge multiple shading tables into one zone or merge several tables to form a bigger table.
I often model the PV system on skethup and then import it into the scene. In doing so each panel appears as its own table.....The problem then arises when I want to distribute the models according to the tables. Since every table is defined as having one module, the auto distribution doesn't work well.
I want to know if there is a way to merge the tables that's imported into larger tables instead of tables consisting of one module or if there is a way to relate groups of tables to each other so that the automatic distribution of modules can identify which modules of the string should be kept together.
Please advise what's the best way to do this
