Timothydiz
Everything posted by Timothydiz
  1. Database will be filled with 5min values. But the Graph will be hourly. What have to be changed to get the 5min graph?
  2. Can you please add an option in the settings to hide the YoWindow system tray icon please? Thanks
  3. The Global incident is just the result of the transposition of your meteo data GlobHor to your tilted plane. With tracking arrays, when using backtracking, this could change when you change the width of the trackers or the pitch between trackers, because the backtracking conditions will vary. In any other case, the Incident Global has no relationship in any way with the rest of the system, such for example the AC capacity.
  4. Hi community, Im looking for a script or pluggin who can move an object to the ground 0,0,0. One click button will be great like F3 in Lightwave. Thanks Phil
  5. I often do simulations of big sites and they require quite a long time to complete the shading calculations in the 3d scene part. It happened that I left them doing it overnight or anyway when Im not around and it can happen that for any reason the computer restarts or switch off suddenly, especially after the calculations are over but before I could save the simulation therefore losing all that work. Could you make it so it would save the shading tables automatically when it finishes calculating it? On a different but related point: is it possible to make it so heavy 3D scenes dont slow down every other part of the software? Now if I want to change something after importing a big scene, it takes minutes just to open different panels. Thanks for your time and best regards
