chanasith janngurn joined the community
Do you have an updated estimate for when this will be implemented? -
mcsgchd joined the community
Thanks for your quick response Auriane! Now I have a problem inserting the .MET file, I get the following error: I've been searching for information and other people on the forum had the same problem when importing the file from "Known Format". When I try to simulate the project I get the following error that prevents me from simulating: I was checking if the data in "Monthly best clear days graph" was correct and if it seems to resemble the data in Excel. I've read that there's a problem with the known format import function in PVsyst, and with the “Convert UTC to local time” in the NSRDB viewer. I would like to know if the error continues to appear, since the forum page where I have consulted all this information is more than a year old, and where I can find how to convert from UTC to Local Time. Thank you! -
Michele Oliosi started following Como añadir una variable en el informe de Pvsyst and Electric layout
@Yvano I see. Thanks for the clarification. Indeed, as mentioned by @André Mermoud the only way currently is to use the automatic attribution instead of the manual one to reach these overlapping modules. I will record this issue for future improvements.
Hi please make a new post in English or translate this one (including the title). Following the language rule will allow us to help more efficiently and also help other users 🙂 -
Khalid Omer joined the community
LPeterson replied to LPeterson's topic in Meteo data
Following up on this, I reverted back to version 8.0.1 and I am no longer having this issue. So it seems like a bug was introduced at some point. -
Could you please explain why?
LPeterson started following Weather file import not working. "The hourly data are not defined."
When importing a weather file for a new project, I am getting an error that says "Invalid weather file: The hourly data are not defined." I am using the same process I have always used, where I define the coordinates of the site and then import weather data from SolarAnywhere (see screenshot), but not I am getting this error which I have never gotten before. I also tried using NREL/NSRDB, and I am getting the same error. Is this a bug? I just updated to version 8.0.17.
Tshego started following Near Shadings 3D scene assistance
Good day, so I am simulating a 1.4 MW pv plant and I am struggling with the near shadings tool. I previously did the simulation using a single row and now I imported the 3D scene and shaped the PV plant area according to the land parcel. I now get the error as shown in the screenshot whereby the number of PV modules in my 3D scene, is half of my PV system defined number of modules. Can anyone help in rectifying? I have tried increasing the land area, youtube, but none have a way to find a solution for matching the PV system number of modules as well and the 3D scene.
Tshego joined the community
Auriane Canesse started following How can I import a quarter-hourly meteo file into PVsyst?
You can import 15 min data via the custom file function of PVsyst. Just note that the data will be averaged and the simulation will still be in hourly steps https://www.pvsyst.com/help/meteo-database/import-meteo-data/custom-meteo-files/index.html Now for the merging part, you cannot do this in PVsyst. If you would like to use a mix a data sources, you should first create a .CSV file that has all your data. Please be careful when doing so that your data corresponds to the same place. But please also note that in your case having global horizontal irradiance and ambiant temperature should be enough to create a .MET file and run your simulation. There is no need to merge anything. -
Hello, Thank you for reaching out. Arial Unicode Normal font may be missing from your computer. Could you please check that you have it installed in your C:Windows>Fonts folder (Normal and Bold should appear for Arial Unicode MS) : https://desk.zoho.eu/api/v1/threads/200072000001797064/inlineImages/edbsn7b09642fb0c92558ad8ffc2319c06c6aae8eae894ba35cc03ed977ae672c483390bfd10deca24a57142d1e0249d0d3edbb5657da68ac8273f7de1e0bd4309326faa955ca0dfb52784be482642ded7957?et=19a59591169&ha=ec3fec97486c37d0383b8b56f46c6dca941a44e833e4fcab4f70546a8c67d2a8&f=1.png If not you can install it from here: https://freefontsdownload.net/free-arial-unicode-ms-font-36926.htm Should you need any further assistance, please do not hesitate to reach out directly at support@pvsyst.com. Kind regards, Laurent
Ameer joined the community
Matodman joined the community
Enzo Melgar started following Como añadir una variable en el informe de Pvsyst
Buenas tengo una consulta, al generar el informe de pvsyst quiero que muestre la energia util a la salida del sistema ya que esa es la energia que se entrega. Pero no veo la opcion de añadirla en el informe. Les adjunto las variables disponibles para añadir al informe, gracias de antemano
As quick extra note: according to the comparison paper by Gueymard and Ruiz-Arias [1] quoted above, the best performing model is in fact "Engerer 2" [3], since it is developed specifically for one minute data. However the next best model is the DIRINDEX [4] model, which is basically DIRINT with an additional predictor based on applying a clear sky model. It would be great it PVsyst could consider using some of the more modern decomposition models, especially considering the use of high-frequency irradiance data. [3] Engerer, N. A. (2015). Minute resolution estimates of the diffuse fraction of global irradiance for southeastern Australia. Solar Energy, 116, 215–237. https://doi.org/https://doi.org/10.1016/j.solener.2015.04.012 [4] Perez, R., Ineichen, P., Moore, K., Kmiecik, M., Chain, C., George, R., & Vignola, F. (2002). A new operational model for satellite-derived irradiances: description and validation. Solar Energy, 73(5), 307–317. https://doi.org/https://doi.org/10.1016/S0038-092X(02)00122-6
