Enzo Melgar joined the community
Abak Aji joined the community
sebastian_samson joined the community
Santiago joined the community
surronbike02 joined the community
PatrickDoyle joined the community
Katie joined the community
Hi Michele, 🙂. Thank you so much for the swift response. Yes, I was also confused by the same thing. I have shared the project file via email, as requested. Your assistance and guidance is really appreciated.
