SGI joined the community
sana11 joined the community
Charlie joined the community
Neill joined the community
arisk joined the community
sanjeev joined the community
Dear Ville, Unfortunately, with a central inverter in PVsyst, it's not possible to perform what you want to do. You can try to modify the OND file by allowing multiple MPPTs, but this will not reflect reality. Regards, - Earlier
OSS_QV joined the community
Hello, The cause of the drop appears to be the irradiation. Do you know why this could occur, it seems unrealistic.
