Lazare Fesnien started following sdfsd
You can find some data about the current and voltage degradation in the works, namely, of the TISO in Switzerland. For example in this publication: https://www.researchgate.net/publication/256080133_TISO_10_kW_30_years_experience_with_a_PV_plant - Today
Farkhi joined the community
MBU_3E joined the community
fabrizio joined the community
yamahaoutboards6 joined the community
Siddanth Gokuldev joined the community
Simon 33 joined the community
