DUARTE Jean-Marc joined the community
N.Y. joined the community
kasemsin joined the community
Robert Boateng joined the community
additiondare joined the community
ruthik joined the community
KevinsNuast joined the community
Enzo Melgar joined the community
Dear Andrés Fernández, Please email us also at support@pvsyst.com : your PVsyst LOG files (using menu <File> <Export logs>) your project files (using PVsyst menu <Export projects>) so we can try to reproduce the issue you reported. Best regards.
