  2. Today
  3. Yesterday
  4. Hi PVsyst team: Did we do some studies about the temperature and convective heat transfer characteristics of PV module due to the different array pitch,or different array tilt angle,or fixed tilted installation horizontal axis N-S installation. such as the pitch of 1# array is 4.5m, and the pitch of 2# array is 5m, in my opinion, the Uc and Uv coefficient will be different for the two array modules. meanwhile,choosing different sopport for photovoltaic modules can also have an impact on the temperature of the modules. Will future software consider these intricate factors? thanks
  5. Hi, When I do a google search on "export PVsyst shade scene to PVC," the AI response is a long message that includes a description of this process, but when I click on the links the same search returns, this process isn't included. I also don't see an appropriate option under "Files" in the shading scene window. I would love to be able save my (updated) shading scenes as PVCs, but I now suspect that this is a case of AI hallucination. Is it, in fact, possible to do this export? If not, can I suggest adding this feature? Thanks.
  6. Last week
  7. The monthly values do not tell whether PV generation and load are aligned all the time. If you don't have any storage in the system, the load may not be covered in different situations, like outside daylight hours, early in the morning or evening if the load is high, or during cloudy periods in the middle of the day. Therefore, it is quite normal, that you cannot self-consume all the monthly or yearly PV generation, even if it is less than the integrated consumption.
  8. Your understanding is correct. The batch mode of PVsyst will indeed not change the number of modules, strings or inverters when you change the pitch. You need to specify those parameters explicitly for each simulation in the batch run and ensure beforehand that they are consistent. In your scenario, where you have standardized containers that will take the PV modules, it should not be too hard to calculate the number of strings that work for a given pitch, and possibly adapt the number of inverters or MPPT inputs. This will give you a limited number of scenarios, for which you then need to vary the tilt. The simplest approach for your case would be to create the batch parameter file with PVsyst, where you choose as parameters tilt, pitch, number of strings and number of inverters (or MPPT inputs). Import this file into a spreadsheet software like Excel or LibreOffice, and fill in lines for all combinations of pitch and tilt. For the number of strings use a formula that computes the number you can fit on the containers as function of the pitch. For the number of inverters use a formula based on the number of strings. If you save this again in CSV format, you can proceed to run the batch simulations. If you are unsure about what PVsyst will do exactly in a given batch simulation, you can use the option 'Calculation version for specified runs', when you first define the batch parameters. This will create an additional column in the batch parameter file, where you can fill a 'Y' for runs you would like to cross-check. These runs will then create variants in your project, that you can open and examine once the batch run is finished. To easily spot these new variants in the project, PVsyst will use the 'Comment' column to generate the titles of the variants.
  9. When I put my system layout in, it is giving me this error. I checked my project and there is nothing wrong with this. Also I only have 2 orientations but PVsyst made it 3.
  10. Hello, When I try to import my 3d scene from VirtoCad as usual, since the new update there is a problem. When I import the scene as usual, I can't 'find' my scene, while it does see the amount of panels it gave a bug with the orientations. Before the update I could just work like this and now I can't use pvsyst. It happens with every project. Can you please help me with this? Thank you in advance.
  11. Hi, For a schoolproject i am investigating different ways to integrate PV on standardized containers. Now, with a batch simulation i want to evaluate the pitch and tilt in order to find the maximum yearly energy. It's not entirely clear to me what happens to the number of modules when the pitch changes. With a fixed available area, increasing the pitch should reduce the number of modules that can fit, and therefore also decrease the total energy production. If I understand correctly, PVsyst doesn't take this into account automatically, and you have to manually calculate how many panels fit within the area for each pitch value. Do I understand this correctly? And if so, could you explain the easiest way to do this? Thanks!
  12. Indeed, this is interesting. As you say, changing the backtracking pitch can be done in PVsyst, but not a different one for morning and evening. Thanks for the feedback !
  13. Hi Evan, Thanks for the project file. Indeed, PVsyst has a problem with the "Shadow Casting" setting on PV fields. According to the documentation (https://www.pvsyst.com/help/project-design/shadings/partial-shadings-and-calculations.html?h=casting#shadow-casting) this setting should not prevent PV fields to receive shadows from surrounding “shadow casting” objects. I have raised a software change request to address this issue. In the meantime, please turn the shadow casting for all your PV objects ON (setting by default). Cannot really think about a scenario requiring the shadow casting of PV trackers field tuned OFF anyway. As far as I can see non-PV Objects behave as expected, they cast shadow on PV fields according to their settings. Best regards, Eric
  14. Hi Eric, I checked and the partial shading calculations is not on. I have emailed the example project file as a follow-up. Thank you for your help, Evan
  15. Hi Evan, Thanks for posting on the PVsyst forum. Can you check you don't have the "partial shading calculations" turned ON ? https://www.pvsyst.com/help/project-design/shadings/partial-shadings-and-calculations.html?h=partial#shadow-casting Alternatively, if you can export your project and send it to : support@pvsyst.com , I will be happy to take a look. Best regards, Eric
  16. Dear Customer, Please send an email to PVsyst support at: support@pvsyst.com with your PVsyst .log files (that you can easily export using menu <File> <Export logs>) so we can analyze what happened. Best regards.
  17. Earlier
  18. Dear Arisk, Unfortenately, this is not possible. Regards,
  19. Hello, In PVsyst 8 (replicated in 8.08, 8.10, 8.11 on multiple computers), there is a near shading bug when only some objects (not all) are selected to cast shadows, shading drops to zero when there should still be shading from the objects selected to cast shadows. I've attached screenshots from an example project demonstrating the bug. Shade scene: Shading loss (zero):
  20. When I try to access my interactive map, it's not available because of my internet connection, but my internet is working without any problems. How can I fix that?
  21. This occurs on uneven terrain. For example, in a plant with east-to-west slopes and a homogeneous pitch, shadows can differ significantly between morning and afternoon. To minimize shading, it's common to set a lower (fictitious) backtracking pitch than the real one when the tracker is facing uphill (either east or west, depending on the case). I know I could simulate this using two separate PVsyst simulations and then combine the results, but of course, it would be better if this could be configured directly in PVsyst. Thanks!
  22. Hello everyone, Is it possible to create a report per MPPT, string or sub-array? I read in an old forum post from 2015 that this wasn’t possible back then. I would like to analyse the power losses due to shading per string. Thanks for your help!
  23. PVsyst V8.0.10 -> Grid-connected -> Load Demo utility project (_DEMO_Utility.PRJ) -> VC4 -> Detailed losses -> Ohmic Losses -> Uses a HV transformer -> Dropdown menu HV to MV Transformer does not work.
  24. Hi. Thank you for the additional information. PVsyst reads the content of the PVC files and applies a translation if X/Y/Z are not 0. If you don't get the expected results, maybe there is an issue with the PVC files. Can you send us the 2 files by email at support@pvsyst.com? We will check further to identify the source of the issue.
  25. Hi Stèphane, thank you for the suggestion. Unfortunately, by setting "Automatic" and to set X, Y and Z to 0, it overlaps in a wrong way the two plots. It seems that PVsyst considers the centre of gravity of the trackers and not the one of the perimeter. I report here below a screenshot of the outcome: the two perimeter should be perfectly overlapped and the structures should be complementary.
  26. Dear Ville, Unfortunately, with a central inverter in PVsyst, it's not possible to perform what you want to do. You can try to modify the OND file by allowing multiple MPPTs, but this will not reflect reality. Regards,
  27. Hi. On the import window of the PVC file, you need to uncheck "Automatic" and to set X, Y and Z to 0: This way each plot will be imported at its original location.
  28. Hello, While working on simulations using the Self Consumption option, I have noticed that the results seem to reflect the behavior of a PV system fully integrated into a local installation. However, in the context of virtual net billing projects, the way the Unused Energy (grid limitation) is calculated does not seem fully accurate. Specifically, the model appears to prioritize the self-consumption of the load first, and only afterwards considers the grid limitation when calculating unused energy. In virtual net billing schemes, where the PV system is not physically connected to the load but compensation is done financially, this logic does not apply directly. The priority should be given to the grid limitation independently of any local consumption. Is there any planned feature or workaround to correctly simulate this behavior in PVsyst? If not, could you please consider implementing an option for such cases in future updates? Thank you in advance for your support.
  29. PVsyst 8.0: I’m modeling a grid-tied, zero-export PV system (no batteries) and encountering an issue where the grid supplies power even when solar generation is available.For example, in January, Solar should cover all possible load (73.7 + 82.2 ≈ 156 MWh), leaving only 25 MWh to the grid. Instead, the grid supplies 107.5 MWh, and 82.2 MWh of solar is wasted. I have set grid limitation to 0 kW (no export) and applied at the inverter level.
  30. Thank you very much for your help Regards!
