sebastian_samson joined the community
Santiago joined the community
surronbike02 joined the community
PatrickDoyle joined the community
Katie joined the community
Stephan Sartor joined the community
solsken energy llp joined the community
bab joined the community
Hi Michele, 🙂. Thank you so much for the swift response. Yes, I was also confused by the same thing. I have shared the project file via email, as requested. Your assistance and guidance is really appreciated.
