JORGE ELIECER CHACON F. joined the community
Vũ Thế Duy joined the community
In PVsyst, the model for the reverse characteristics is this quadratic expression. This corresponds rather well to the reality, but this is a rough approximation. By the way the values of this model have a quasi null impact on the PVsyst simulation results. Now the term (Rserie * I) is indeed a little contribution (perhaps it should not be taken into account, we will check). You can forget it.
If it still doesn't work you can always model it as I have above 🙂 The gaps will not matter for bifacial calculations, they are not used. The user defines the transparency factor manually which takes into account gaps in structure, modules, etc. So I'd either model as I have or increase the gap in your method if the suggestion above does not work.
Thana joined the community
Adeline replied to Adeline's topic in Simulations
Thank you for the fast response! is it possible for you to share some ways to indirectly estimate? Yes! I am looking for the purpose of glare regulations -
Excuse me, Prof.Andre Mermoud is I the reverse current in this formula,so a more accurate representation would be IRev = Iph +aRev *(V+Rs * IRev) ;and the externally forced current is IRev? thanks for reply.
Eylül Nazlı YAMAN joined the community
You're a great help Jéremie! Thank you.
Dear User, In this case, please email us at support@pvsyst.com your PVsyst LOG files (menu <File> <Export logs>) so we can analyze what happened. Best regards.
Excuse me, but this problem happens with any project.
André Mermoud started following externally forced current
This tool shows what happens for a specified current (i.e. imposed by the rest of the string). You can drag the red point of this forced current for analysing what happens at different values. The voltage of this point is the result of the reverse characterisics model: You can find this formula in the help https://www.pvsyst.com/help/physical-models-used/pv-module-standard-one-diode-model/reverse-characteristic-of-a-cell.html The temperature is obtained by applying the U-value on this cell, taking the dissipated power as input parameter instead of GlobInc.
Hello, the difference between the axis tilt of the field and the average orientation it belongs to is higher than the default tolerance for this parameter. You can adjust this tolerance in the advanced parameters. To find it, use the search filter and type 'tilt'. The relevant parameter in this case is 'Tracking: maximum axis tilt spread'. You can set this tolerance to 13
apiconnects joined the community
as we can see the three values on the figure, the V (-5.2V),I(7.93A) and P(128W),Is there a formula that can explain their relationship,thanks!
Dear pvsyst team: I am using this software to simulate the temperature and power when a cell is local shading. I find that “externally forced current= 4.4A” is all the same for the different solar modules. What does it mean? thanks!
Aidenn started following Warnings during initializations
Hi PVSyst Team, I already generated the PVSyst report and these warnings appear during initialization. The 3D scene comes from PVCase and a TFT. Can someone assist how to deal with these errors? Appreciate your help.
Yes, that's correct. The site I was working with had the trackers tilted on the terrain with different tracker heights and axis tilts. The custom diffuse tracker that I had selected in version 7.4.8 worked with the selection of adjacent masking trackers. But after importing the project to version 8.0.9 the masking selection did not select the adjacent trackers and I had trouble getting that to work.
Bruno Wittmer started following Potential Bug in "Weather data tables and graphs"
Bruno Wittmer replied to Hung MAI's topic in Problems / Bugs
Thank you for reporting this problem. It will be fixed in one of the next PVsyst versions. -
Nils Lang started following Multi-thread problem
Dear User, You can use PVsyst menu <File> <Export projects> to easily export your project files in a ZIP file and email it to our support address: support@pvsyst.com with your PVsyst LOG files (menu <File> <Export logs>) so we can analyze what happened. In the meantime, you can already read our FAQ about the most efficient way to optimize PVsyst simulation time: https://forum.pvsyst.com/topic/3542-how-to-optimize-simulation-time/?do=findComment&comment=9867 Best regards.
Denis started following Multi-thread problem
Good day! I have a 32 core processor but cant use it for full power( Every time when I try to turn on "Enable multi-threading" flag PVSyst stop working without any crashes. When I try to open any project its freezes in endless loading. When this option off program working well, but calculations calculations are sooo slow. How can I fix that?
Denis joined the community
CarlosSolis started following Lidar data import method
Danidu joined the community
Hi Auriane, I have since made change to that variant, and when re-running it I am not seeing anything as extreme as the situation I posted above. However, there are still some very fast drops from almost max power to very low power (but not zero). I have sent across the project files to PVsyst support email anyway for you to investigate. Kind regards, James. -
Ady joined the community
Geometry Dash Scaling module dimensions in the PAN file does not directly affect energy output—it mainly affects shading calculations and layout visualization. Energy yield depends on electrical parameters, not physical size. In contrast, specifying collector band width (used in 2D shadings) does influence energy results, as it determines how much of the collector surface is exposed or shaded, directly affecting irradiance and losses.
